> At 07:00 AM 11/19/2008 +0100, Hendrik B=C2=8A=C3=A4cker wrote:
>>> The patch adds a new directive "services" to the "host" definitions.
>>> This new directive lists one or more "service" templates which
>>> are used to automatically create "service" definitions for
>>> the host.
>> I've just did a fast read on your patch. Nice work that you patched th=
e
>> documentiotion, too.
>=20
> Thanks.
>=20
> BTW, after I sent the patch, my nagios servers started abending.
> It seems that I "cleaned" up the patch too much.
> I'll send an updated patch later in the week, once I'm 100%
> positive that it will be ok. I even found a better place to do
> the auto-instantiation that allows me to handle host templates
> as well.
>=20
>> But to the patch: Why do you do it in a host atomic way while it might
>> be less work when doing it on hostgroups?
>=20
> Actually, in my experience, it would be a *lot* more work to do
> the same with hostgroups as I had to define one hostgroup per
> service "kind" that I needed to monitor: 1 service + 1 hostgroup.
>=20
> Using this new keyword, I only have to define one service template
> for however many hosts happen to need that service check.
>=20
> It also allows me to use hostgroups to group hosts by categories
> like mail servers, web servers, compile farm, sybase server, etc.
>=20
> Let me give you an example. We have a few dozen NetApps.
> All these netapps have the exact same function: file servers.
> But each one has a different number of volumes defined and in some
> cases, the volume names are not even consistent: eg, one of the
> netapps has vol0, vol1 and vol3 defined (vol2 was removed a while
> back) while others have the sequence vol0, vol1, vol2 and vol3;
> others have a single volume and others have a much larger number
> of volumes.
>=20
> If I were to use hostgroups, I would have to define a hostgroup
> per volume name, but then I'd lose the possibility of
> classification by function (well, not _lose_ but it would get
> clouded among hundreds of artifact hostgroups, required only
> by the config files).
>=20
> Makes sense?
Yes, makes sense.
I will test your next patch ASAP on my test systems.
Joerg
