Thanks for the note Peter - I'll post a patch to CVS which should fix
this.
Peter Ringe wrote:
> Hi Ethan, hi al,
> I think there is a problem in base/utils.c, when comparing the string,
> found in the perl script with
> "+epn" or ".epn" .
> There Ehtan has used strcmp
> if(!strcmp(ptr,"+epn")){
> use_epn=TRUE;
> found_epn_directive=TRUE;
> else if(!strcmp(ptr,"-epn")){
> use_epn=FALSE;
> I think (I'm not amn c expert) instead of strcmp, strstr would be better
> due to leading/trailing whitespaces linefeeds in ptr. actually
> actually with
> # nagios: -epn"
> ptr will be " +epn\n", the leading blank as well as the trailing
> linefeed is part of ptr
> regards,
> peter
> william(at)elan.net schrieb:
>> On Wed, 11 Jul 2007, Hendrik Baecker wrote:
>>> Hi Ingo,
>>> Ingo Lantschner schrieb:
>>>> But to my understanding of the tag "#nagios: -epn" it should disable
>>>> epn for the particular plugin even if use_embedded_perl ist set to 1.
>>>> But unfortunately the output still gets messed up.
>>> yes - this should do the trick, but after regarding the docs it should be
>>> "# nagios: -epn" instead of
>>> "#nagios: -epn"
>>> There is a blank between '#' and 'n'.
>> While this is all fine, a simple way (that also works with any 2.x
>> code) based on how nagios decides if it is or not a perl plugin is to
>> just remove the first line "#!/usr/bin/perl" from pliugin and in
>> commands.cfg instead of just specifying plugin name directly add
>> explicit call to /usr/bin/perl, i.e.
>> command_line /usr/bin/perl your_plugin.pl
> This SF.net email is sponsored by DB2 Express
> Download DB2 Express C - the FREE version of DB2 express and take
> control of your XML. No limits. Just data. Click to get it now.
> http://sourceforge.net/powerbar/db2/
> Nagios-devel mailing list
> [email protected]
Ethan Galstad,
Nagios Developer
Email: [email protected]
