Re: [Nagios-devel] Tinderbox
On 4 Nov 2010, at 10:58, Andreas Ericsson wrote:
> Nagios' tinderbox, http://tinderbox.nagios.org/nagios/status.html,
> shows one buildbox as failing due to TAP::Parser missing. If the
> person responsible for that systems is on this list, I'd take it
> kindly if you could re-install that package.
Oooh! Lots more tinderboxen! Where did those come from?
> Ton, if the build is still failing on that system in a week, could
> you remove it from the tinderbox page?
The way it works is just based on whoever sends reports in. I guess I
could hack the code to ignore reports from certain hostnames, but
that's not currently possible.
Ton
