Content-Type: text/plain; charset=UTF-8
On Fri, May 15, 2009 at 11:55 AM, Matthieu Kermagoret
wrote:
> This issue has been successfully reproduced on Nagios 3.0.6, 3.1.0 and
> the latest CVS revision with NDOUtils 1.4b7.
Can still be reproduced with latest Nagios CVS revision. This is now
the oldest unassigned issue within Nagios' tracker
(http://tracker.nagios.org/view.php?id=3D4)
You'll find attached a patch which tries to correct Nagios' behavior.
It causes host/service status not to be updated when check is
scheduled but only when check results are processed. Is there any
weird case that would cause this logic to fail ?
Best regards,
--=20
Matthieu KERMAGORET | D=C3=A9veloppeur
[email protected]
MERETHIS est =C3=A9diteur du logiciel Centreon.
--0016364165fb7b29b40480326762
Content-Type: text/x-diff; charset=US-ASCII;
name="nagios_status_update_function_called_twice.patch"
filename="nagios_status_update_function_called_twice.patch"
X-Attachment-Id: f_g5zft2zg0
ZGlmZiAtTmF1ciBhL2Jhc2UvY2hlY2tzLmMgYi9iYXNlL2NoZWNrcy5jCi0tLSBhL2Jhc2UvY2hl
Y2tzLmMJMjAxMC0wMi0yMiAxNjozNzoxNy4wMDAwMDAwMDAgKzAxMDAKKysrIGIvYmFzZS9jaGVj
a3MuYwkyMDEwLTAyLTIyIDE2OjQwOjE3LjAwMDAwMDAwMCArMDEwMApAQCAtMTc3NSwxMCArMTc3
NSw2IEBACiAJCWxvZ19kZWJ1Z19pbmZvKERFQlVHTF9DSEVDS1MsMiwiS2VlcGluZyBvcmlnaW5h
bCBzZXJ2aWNlIGNoZWNrIGV2ZW50IChpZ25vcmluZyB0aGUgbmV3IG9uZSkuXG4iKTsKIAkJfQog
Ci0KLQkvKiB1cGRhdGUgdGhlIHN0YXR1cyBsb2cgKi8KLQl1cGRhdGVfc2VydmljZV9zdGF0dXMo
c3ZjLEZBTFNFKTsKLQogCXJldHVybjsKICAgICAgICAgfQogCg==
--0016364165fb7b29b40480326762--
