Re: [Nagios-devel] eventhandler timeout 3.0.4
I already posted this issue a while ago, see
"[Nagios-devel] blocking character of event_handlers" on the list.
Regards,
Michael
Am 29.10.08 14:53 schrieb "Sven Nierlein" unter :
> Iretried this test with the 3.0.4 which resulted in the same behavior.
>=20
> I installed a fresh installation from the sources, with just one
> servicecheck.
>=20
> Nagios works fine till the eventhandler has to be executed:
>=20
> nagios.log:
>> [1225287417] Nagios 3.0.4 starting... (PID=3D2345)
>> [1225287417] Local time is Wed Oct 29 14:36:57 CET 2008
>> [1225287417] LOG VERSION: 2.0
>> [1225287417] Finished daemonizing... (New PID=3D2346)
>> [1225287547] SERVICE ALERT: localhost;test;CRITICAL;SOFT;1;(null)
>> [1225287547] SERVICE EVENT HANDLER:
>> localhost;test;(null);(null);(null);sleep
>=20
> nagios.debug:
>> [1225287547.230915] [2048.1] [pid=3D2346] Done. Final output:
>> 'SERVICE ALERT: localhost;test;CRITICAL;SOFT;1;(null)'
>> [1225287547.230921] [2048.1] [pid=3D2346] **** END MACRO PROCESSING
>> [1225287547.231080] [064.1] [pid=3D2346] Making callbacks (type 9)...
>> [1225287547.231091] [001.0] [pid=3D2346] handle_service_event()
>> [1225287547.231098] [064.1] [pid=3D2346] Making callbacks (type 30)...
>> [1225287547.231111] [001.0] [pid=3D2346] run_global_service_event_handler(=
>> [1225287547.231118] [001.0] [pid=3D2346] run_service_event_handler()
>> [1225287547.231125] [016.1] [pid=3D2346] Running event handler for
>> service 'test' on host 'localhost'...
>> [1225287547.231136] [064.1] [pid=3D2346] Making callbacks (type 11)...
>> [1225287547.231155] [001.0] [pid=3D2346] get_raw_command_line()
>> [1225287547.231163] [2320.2] [pid=3D2346] Raw Command Input: /bin/bash
>> -c "sleep 300"
>> [1225287547.231170] [2320.2] [pid=3D2346] Expanded Command Output:
>> /bin/bash -c "sleep 300"
>> [1225287547.231177] [016.2] [pid=3D2346] Raw service event handler
>> command line: /bin/bash -c "sleep 300"
>> [1225287547.231184] [001.0] [pid=3D2346] process_macros()
>> [1225287547.231190] [2048.1] [pid=3D2346] **** BEGIN MACRO PROCESSING
>> [1225287547.231197] [2048.1] [pid=3D2346] Processing: '/bin/bash -c
>> "sleep 300"'
>> [1225287547.231203] [2048.2] [pid=3D2346] Processing part: '/bin/bash
>> -c "sleep 300"'
>> [1225287547.231211] [2048.2] [pid=3D2346] Not currently in macro.
>> Running output (24): '/bin/bash -c "sleep 300"'
>> [1225287547.231218] [2048.1] [pid=3D2346] Done. Final output:
>> [1225287547.231234] [2048.1] [pid=3D2346] **** END MACRO PROCESSING
>> [1225287547.231241] [016.2] [pid=3D2346] Processed service event handler
>> [1225287547.231327] [064.1] [pid=3D2346] Making callbacks (type 9)...
>> [1225287547.231336] [001.0] [pid=3D2346] my_system()
>> [1225287547.231344] [256.1] [pid=3D2346] Running command '/bin/bash -c
>> "sleep 300"'...
>> [1225287547.231367] [064.1] [pid=3D2346] Making callbacks (type 10)...
>> [1225287547.231967] [001.0] [pid=3D2451] process_macros()
>> [1225287547.231997] [001.0] [pid=3D2451] process_macros()
>> [1225287547.232013] [001.0] [pid=3D2451] process_macros()
>> [1225287547.232028] [001.0] [pid=3D2451] process_macros()
>> [1225287547.232042] [001.0] [pid=3D2451] process_macros()
>> [1225287547.232056] [001.0] [pid=3D2451] process_macros()
>> [1225287551.231246] [016.2] [pid=3D2448] Moving temp check result file
>> '/tmp/nagios/var/spool/checkresults/check13kIOP' to queue file
>> '/tmp/nagios/var/spool/checkresults/cn2NyLo'...
>>=20
>> *** 300sec gap ***
>>=20
>> [1225287847.239230] [256.1] [pid=3D2346] Execution time=3D30.001 sec
>> , early timeout=3D0, result=3D2[1225287847.239309] [064.1] [pid=3D2346]
>> [1225287847.239332] [064.1] [pid=3D2346] Making callbacks (type 11)...
>> [1225287847.239341] [001.0] [pid=3D2346] check_for_external_commands()
>> [1225287847.239350] [064.1] [pid=3D2346] Making callbacks (type 18)...
>> [1225287847.239376] [016.1] [pid=3D2346] Rescheduling next check of
>> service at We
...[email truncated]...
