Re: [Nagios-devel] waste of cpu in status summary
On 10/27/2010 04:51 PM, Sven Nierlein wrote:
> Dear list,
> introduced with http://nagios.cvs.sourceforge.net/viewv ... 81&r2=1.82
> the servicegroup summary calculation has been corrected, but unfortunately a useless loop over all
> services for every host has been left over. This leads to very long loading page times. The Servicegroup summary for all
> groups took around 8seconds but the summary for a single group took over 8 minutes.
> Please have a look at the attached patch (diff is against the 3.2.3 release) which removes the useless loop.
> The patch is sponsored by TomTom, so if you want to give kudos to someone, then TomTom are the ones you are looking for.
Thanks. I'll forge your signoff and just pretend you gave me explicit
permissions to include it in future Nagios releases.
Should be in CVS in a couple of minutes, and on git.op5.org in a few
more.
OP5 AB www.op5.se
on peace.
