Re: [Nagios-devel] Fix some compiler warnings
On 2010-05-01 18:05, Stephen Gran wrote:
> Hi all,
> I noticed that building NDO with -Wall resulted in a few compiler
> warnings, so I fixed them up while I was looking at other things. The
> attached patch is the result.
Yep that's true - instance_id is defined as "%lu" aka "unsigned long"
and at several calls it's being handled as "%d" which is rather
annoying. Regarding compiler errors, I also need to fix several things
on IDOUtils though ;)
Maybe someone like you will able to maintain NDOUtils and fix those
things - we will do on Icinga though :)
> Again, if you'd prefer it in git-am style, that's fine, just let me
> know.
I would prefer this really, since in a while Ethan should at least say
"hey GIT is cool, Andreas develops it, we should take care of it"
Meanwhile, I've recognized such issues while building packages on Icinga
IDOUtils - maybe you'd like to test and write something over there?
Kind regards,
Michael
