[Nagios-devel] Nagios chops error text after ~430 chars
hi
When I try sending the following error (1) (clipped from the event log), =
it=20
cuts it off, leaving only the this (2) left. The clipped text is then use=
d in=20
the notification.
any chance of getting the full text?
I've tried several times, and it looks like there's a low buffer somehow.=
How=20
can I change this? I _need_ long logs.
roy
1
[25-04-2003 14:00:37] EXTERNAL COMMAND:=20
PROCESS_SERVICE_CHECK_RESULT;display01;CP_FLYTOGET_LODALEN;1;Not ready ye=
t.=20
But might be. Don't know. Might be ok. Might be broken. Unable to tell. I=
t's=20
just Windows. Or unix. OS/2? I don't know. Total confusion. As if in a=20
relation to Confuctus. I might be wrong, but is this a nagios error repor=
t?=20
Possibly. But more likely, I'd say it's closer to a rather bored sysadmin=
=20
write a long passive check text to nagios to see if Nagios has stopped=20
chopping them off in mid sentence. Ok. That's all folks.
2
Not ready yet. But might be. Don't know. Might be ok. Might be broken. Un=
able=20
to tell. It's just Windows. Or unix. OS/2? I don't know. Total confusion.=
As=20
if in a relation to Confuctus. I might be wrong, but is this a nagios err=
or=20
report? Possibly. But more likely, I'd say it's closer to a rather bored=20
sysadmin write a long passive check text to na=20
--=20
Roy Sigurd Karlsbakk, Datavaktmester
ProntoTV AS - http://www.pronto.tv/
Tel: +47 9801 3356
Computers are like air conditioners.
They stop working when you open Windows.
