Re: [Nagios-devel] [BUG] Missing new line in cmd.cgi [3.0.5]
Hash: SHA1
Andreas Ericsson schrieb:
> Olivier Beytrison wrote:
>> Hi there,
>> I juste upgraded nagios to 3.0.5 and discovered a little bug with
>> the command cgi.
>> If you want to submit a command (like Disable notifications for
>> all services on this host) and you check "Disable notification
>> for host too", the command is not correctly sent to Nagios.
>> Here's the logfile result (:
>> [1225963577] EXTERNAL COMMAND:
>> ENABLE_HOST_SVC_NOTIFICATIONS;hesidp[1225963577]
>> ENABLE_HOST_NOTIFICATIONS;hesidp
>> As you can see, there's a missing new line, thus making 2
>> commands on one line, and unreadable for nagios.
>> I saw that the code of cgi/cmd.c has been changed, I tried to
>> simply add a \n in the cmd_submitf() function, but didn't work.
>> could you please look into this problem, and submit a patch ?
> I'll look into it, yes. Thanks for reporting it.
I spent some time on this.
each external command has to end with a newline character because the
later fputs() to the command file.
@Andreas:
Do you see any security risk when putting an "\n" to the end of cmd in
"cmd_submitf()"?
Seems to me as the easiest way.
Hendrik
-----BEGIN PGP SIGNATURE-----
Version: GnuPG v1.4.7 (MingW32)
iD8DBQFJEu8KlI0PwfxLQjkRAnQ8AKCAjLYedcts5V3kJuOLEW4n/M9CXQCfcDRF
8//EIyU68hD2sP3hW5hVOEM=
=jSga
-----END PGP SIGNATURE-----
