Re: [Nagios-devel] A different way?
Steven D. Morrey wrote:
> Hello everyone,
> I've decided to take a break for a bit from multi-threading nagios to focus on DNX since that is my day job after all :)
> While working on all of this I had a few thoughts that might make some good ideas if Nagios is ever re-designed again, say for a 4.x branch.
> As you know, under nagios, all checks are dispatched by nagios to be executed on the local machine at set intervals.
> Under a distributed nagios setup, you have multiple nagios instances running on various machines executing checks and passing the results back to a passive master controller.
> Under DNX, we distribute the load to "worker nodes" which then execute the checks and hand the results back to an active master controller that then processes the result etc.
> Profiling shows that (under DNX at least) 2/3rds of our time is spent in the reaper processing results, so wouldn't it make more sense to flip the process around?
> The checks are already executing on the local machine, so how about a daemon on each machine, the daemon would keep the schedule and execute service checks locally, processing the result and returning the results and the required actions (based on a local policy) to nagios which would then do the actual work of handling notifications etc and so forth.
> This way nagios could be an auditor, if it doesn't receive a result on time as expected, then it could query the daemon to see whats gone wrong, if that fails then it could initiate a host check, etc.
>>From a design standpoint this is a bit more work than the current setup, but it seems to me that this could allow for much greater flexibility and scalability in the long run.
> Anyways I hope this sparks a little debate but I don't want to "come in and shake things up", or go around changing everything, stepping on toes all the while, it's just that putting the responsibility of actually executing the check and doing so on time, onto the computer it needs to execute on, just makes more sense to me.
> It's not really dramatically different from what we do now, it's just adding a scheduler/timer to the existing execution framework and adding something to push the original schedule and any changes such as scheduled downtime to the appropriate machines, putting everything else into a semi passive mode effectively turning each machine to be checked into it's own "worker node"
> Thoughts?
sounds sensible to me, from what I've seen most of the full blown snmp
products out there are designed this way, to allow them to scale
largely, I guess the same benefits would be bought to nagios.
it sounds like a lot of work though, and a redesign of nagios internals.
