I have my own web-based interface where I configure and manage everything related to the network (configure firewall, create webserver, add hosts, etc etc.). Now, I want to find a way to include in that interface some application to configure nagios (adding and removing hosts, adding services, etc). Is there any application that manages to do this? Or any plugin? What's the solution?
It could be some application installed on the same machine than Nagios which functions can be accessed by XML or something like that.. Is there any other solution? Thanks in advance.
Regards
André
Nagios configuration via Interface (API)
tonyyarusso
Re: Nagios configuration via Interface (API)
You could take a look at NagiosQL.
aocferreira
it supports PHP API and I access it's functions? i've found Groundwork Foundation, but it seems a little bit complicated..
tonyyarusso
That's more on the web interface side rather than an API. I'm not aware of any easy "create a host" API command for anything, although in combination with NagiosQL you can make your own by writing the proper SQL queries in whatever format is useful to you.
