Hi all.
I was thinking about the way contacts are propagated through the service
and host objects in nagios 2.0, and I found some room for improvement.
I'd like to be able to define contacts on a multitude of levels,
starting with hostgroups and working their way down through
service_groups and finally to services. (this also makes configuration
backwards compatible, which is always a Good Thing).
Here's how I thought it.
A general syntax should be agreed upon to define exactly or add or
subtract reference pointers to other objects.
To _add_ a reference, one would prefix the reference name with a '&'.
To _remove_ a reference, one would prefix the reference with a '!', and
to specify exactly, one would use no prefix at all (like we override
things inherited from templates today).
To specify a group, one could prefix with a '@' (this way configuration
file token support can be kept small).
Not all references would have to support this, but it might be easier to
include it on a general basis.
For example, we have hosts 'server1' and 'server2' which are in
hostgroup 'server-group', looking something like this;
define hostgroup {
hostgroup_name server-group
alias some servers
members server1,server2
contacts @server_contacts,server_admin,!@support_contacts
# all contacts in server_contacts and the contact server_admin
# remove the contacts in contactgroup support_contacts
define host {
host_name server1
alias alias for server1
address 10.1.1.2
contacts !the_boss,&@quake_contacts
# the company quake-server, so don't let the boss know
# it's being loaded too high all the time.
host_name server2
alias alias for server2
address 10.1.1.3
contacts &xerox_workers
# print-server, so store emails where support staff can find them
(I don't know enough about servicegroups yet to give an example of how
it would work)
# this looks silly with only 2 hosts, but you get the idea
use default-service
host @server-group,!server1
service_description Webpage integrity
check_command check_http
contacts @security_contacts,@web_contacts
# override host and hostgroup contacts completely for this service
use default-service
host @server-group
service_description Mailserver
check_command check_nrpe!mailq
contacts !@quaker_group
# inherit contacts from server-group AND server{1,2}, respectively.
# but don't send to @quaker_group
I'd be willing to implement it, but I won't be able to work all too fast.
One of the major benefits of this is that it makes it really easy to
write a webconfiguration interface for it (solid object variable
dependancies). I have done some work in that area, and I'd be willing to
release it to the public if I can make it work properly on Nagios 2.0.
Today, that requires some hacking. It also includes very nice (and
extremely fast) functions to read and parse the configuration files,
making it easy to extend it to replace the C-version of the GUI.
Also, would I wreak havoc on everything if I removed the need for the
'define' word from the beginning of every object statement?
Andreas Ericsson
OP5 AB
+46 (0)733 709032
[email protected]
