Re: [Nagios-devel] [Fwd: Memory leak in Nagios head]
Matthew Kent wrote:
> Forwarding this on in case anyone else has seen this behaviour and has
> some suggestions. I'll give it a run through valgrind and see if I can
> spot anything this evening.
Thanks, Matt.
A small update;
After having run the daemon about 10 hours at a test system, memory
consumption has escalated from roughly 1MB to around 24MB. Not very nice
figures. It seems that sending a HUP makes memory consumption make a
small jump (usually around 20K).
This small script should crash Nagios after a while. It might have to be
run more than once. I haven't tried it very much. It works regardless of
whether or not the eventbroker is compiled in.
#!/bin/sh
pid=`cat /usr/local/nagios/var/nagios.lock`
for i in `seq 1 100`; do
kill -HUP $pid
sleep 1
ps -up $pid || break
done
[ $i -ne 100 ] && echo "Nagios successfully crashed"
With --enable-DEBUGALL, this output is shown by tailing the last 20 or
so lines of the output.
find_host() start (repeats about 40 or so times)
write_to_all_logs() start
write_to_syslog() start
write_to_log() start
write_to_all_logs() end
Caught SIGSEGV, shutting down...
close_command_file() start
close_command_file() end
write_svc_message() start (repeats 4 times)
Another weird thing is that the SIGSEGV crash causes Nagios to remove
the lockfile, but not the objects.cache-file, which causes the
webinterface to happily chug on as if nothing's happened. That should be
fairly easily fixed, but I'd rather get to the bottom of the memory leak.
> Subject:
> From:
> Andreas Ericsson
> Date:
> Mon, 29 Nov 2004 12:47:27 +0100
> To:
> [email protected]
> To:
> [email protected]
> CC:
> [email protected]
> Ahoy Ethan.
> There's a memory leak in Nagios HEAD, causing it to crash when (it
> seems) enough checks has been executed. I would have emailed the
> nagios-devel list but I believe I'm still banned from it pending a
> solution to the sourceforge list server fuckup? Could one of you forward
> this to that list, please?
> It's compiled without embedded perl, and without perl caching, like so;
> ./configure --prefix=/opt/monitor
> I'll start digging today, so I might have a patch ready for you soon.
> I Cc'ed Matthew Kent on this as well, seeing as he's been very helpful
> with the finding and fixing earlier.
OP5 AB www.op5.se
Lead Developer
