------=_Part_37411_24330330.1220657739301
Content-Type: text/plain; charset=ISO-8859-1
Content-Disposition: inline
I think i've found a bug.
in config.c:
At line #1878, temp_service->check_interval is incorrectly assuming
interval_lenght=60, but if one would use an interval_length directive equals
to 1, then the Warnings like: "[1220575781] Warning: Service 'Current Load'
on host 'faeroes' has a notification interval less than its check
interval! Notifications are only re-sent after checks are made, so the
effective notification interval will be that of the check interval." will
incorrectly shows up, because the conditional below assumes interval_lenght
= 60.
(line 1878)
if(temp_service->notification_intervalcheck_interval &&
temp_service->notification_interval!=0){
I don't know exactly where the interval_length could be fetched to correctly
multiply by the value of check_interval and compare it to the "in minutes"
value of notification_interval and send a patch, just saw these warning on a
new install with interval_length = 1, and I think i might report it.
Sorry if this is a known bug and/or if i've missed something.
HTH,
Marcel
Content-Type: text/html; charset=ISO-8859-1
I think i've found a bug.in config.c:At line #1878, temp_service->check_interval is incorrectly assuming interval_lenght=60, but if one would use an interval_length directive equals to 1, then the Warnings like: "[1220575781] Warning: Service 'Current Load' on host 'faeroes' has a notification interval less than its check interval! Notifications are only re-sent after checks are made, so the effective notification interval will be that of the check interval." will incorrectly shows up, because the conditional below assumes interval_lenght = 60.
(line 1878) if(temp_service->notification_interval<temp_service->check_interval && temp_service->notification_interval!=0){I don't know exactly where the interval_length could be fetched to correctly multiply by the value of check_interval and compare it to the "in minutes" value of notification_interval and send a patch, just saw these warning on a new install with interval_length = 1, and I think i might report it.
Sorry if this is a known bug and/or if i've missed something.HTH,Marcel
------=_Part_37411_24330330.1220657739301--
