RE: [Nagios-devel] Config file syntax
That would be so great ...
-----Message d'origine-----
De : D. Roos [mailto:[email protected]]
Envoy=E9 : mardi 29 avril 2003 11:58
=C0 : [email protected]
Objet : [Nagios-devel] Config file syntax
Heyaz,
Would it be much work to change the config file syntax to XML instead of
the current 'define XX { option value }'. Even adding an option to use
XML for configfiles would be great.
Changing the syntax, or adding an option to use XML config files would
make it easier (at least for me ;) ) to parse the config files and use
them in various (PHP) scripts.
Currently I use 'fancy' regexp's to parse the configfile and a nagios
specific function to write the files.
Regards,
Dennis Roos
This sf.net email is sponsored by:ThinkGeek
Welcome to geek heaven.
http://thinkgeek.com/sf
_______________________________________________
Nagios-devel mailing list
[email protected]
https://lists.sourceforge.net/lists/lis ... gios-devel
