This is an OpenPGP/MIME signed message (RFC 2440 and 3156)
--------------enig1942B73AFEFA9BAA9D92B9DE
Content-Type: multipart/mixed; boundary="------------090305030402090506090900"
--------------090305030402090506090900
Content-Type: text/plain; charset=ISO-8859-15
in the config-file there is written:
"# If you don't want Nagios to log passive host and service checks..."
But the regarding check in commands.c doesn't check for
passive_host_checks. My attached patch should fix that (the patch is
against 2.9, but should apply to cvs, too).
--=20
Best regards,
Sven mailto:[email protected]
ClamAV, a GPL anti-virus toolkit http://www.clamav.net
name="passive_logging.patch"
Content-Disposition: inline;
filename="passive_logging.patch"
diff -Nur nagios-2.9-orig/base/commands.c nagios-2.9/base/commands.c
--- nagios-2.9-orig/base/commands.c 2007-08-14 02:58:13.000000000 +0200
+++ nagios-2.9/base/commands.c 2007-08-14 02:58:26.000000000 +0200
@@ -563,7 +563,7 @@
/* log the external command */
snprintf(buffer,sizeof(buffer),"EXTERNAL COMMAND: %s;%s\n",command_id,=
args);
buffer[sizeof(buffer)-1]=3D'\x0';
- if(command_type=3D=3DCMD_PROCESS_SERVICE_CHECK_RESULT){
+ if(command_type=3D=3DCMD_PROCESS_SERVICE_CHECK_RESULT || command_type=3D=
=3DCMD_PROCESS_HOST_CHECK_RESULT){
if(log_passive_checks=3D=3DTRUE)
write_to_all_logs(buffer,NSLOG_PASSIVE_CHECK);
--------------090305030402090506090900--
Content-Type: application/pgp-signature; name="signature.asc"
Content-Description: OpenPGP digital signature
Content-Disposition: attachment; filename="signature.asc"
-----BEGIN PGP SIGNATURE-----
Version: GnuPG v1.4.7 (MingW32)
Comment: Using GnuPG with Mozilla - http://enigmail.mozdev.org
iD8DBQFGwYsSFkZnpPWp1MQRAoGOAKDkPaTJVxkF2pLquFI1GzStEgLw/QCdHy00
14xtjCBs8a6WCWrq011LLRw=
=3Lio
-----END PGP SIGNATURE-----
--------------enig1942B73AFEFA9BAA9D92B9DE--
