Hash: SHA1
On 20/01/09 08:37 AM, Christoph Maser wrote:
> Am Dienstag, den 20.01.2009, 10:41 +0100 schrieb Yann Jouanin:
>> Hello everyone,
>> I am thinking about the way data are stored (status…) and how it
>> impacts performances.
>> As an example, when there is a large number of services or hosts, CGIs
>> become really slow cause it read the whole files. One of my idea to
>> fix this problem would be to use a sqlite3 database instead of flat
>> files.
>> What are your feelings about that (performances, licence…)
> Yann if i understood things right, the future plan is to get rid of the
> current CGIs and dump all information via ndoutils in a (MySQL)-database
> which will be then used by a yet to be wrtitten PHP frontend.
I like the idea of allowing a MySQL backend, but IMHO the it's overkill
for most systems and will cause more troubles than what it's trying to
solve. More importantly, badly tuned MySQL servers will be one more
performance bottleneck.
IMHO the backend should be modular. Nagios's architecture make it easy
to create multiple selectable data backends and I think the PHP web
interface should be as flexible.
I was thinking about it though and I CDB could be a nice match for a
faster data backend. For those who don't know CDB, it is a read-only
ultra-fast database written by D. J. Bernstein
(http://cr.yp.to/cdb.html). Given the way status.dat is written a
read-only replacement makes a good fit and PHP has native support for
reading these databases trough dba_open.
I could try coding it for the development branch if there's any chances
a working implementation gets accepted for a future release. On the php
side though I don't have much coding experience, so while I can most
likely get CDP working I'm not sure how to design a modular backend.
Thomas
-----BEGIN PGP SIGNATURE-----
Version: GnuPG v1.4.6 (GNU/Linux)
Comment: Using GnuPG with Mozilla - http://enigmail.mozdev.org
iD8DBQFJfsdw6dZ+Kt5BchYRAiLcAJ4g18ogwl6a3qu/hg9GlrggL9DZMACeLgWK
fcpWRMzZv/D3nSfdRIyUzrg=
=hCOR
-----END PGP SIGNATURE-----
