Re: [Nagios-devel] ochp problem
I found the problem and am posting a patch to CVS momentarily... give
the CVS code a try when you get a chance to make sure it fixed the problem.
Olivier JAN wrote:
> Hello list,
> I've already posted something about that which is not solved at the
> moment. This is now on nagios 3.0b4.
> Below is two excerpts of my debug file. In first part, this is how a
> ochp is handled by nagios. We can see it finish with a null in the
> command. In second part is the same for ocsp and it finish with a macro
> correctly loaded.
> Can someone explain what can be wrong with my ochp processing. The macro
> seems to be well processed but the final output is not transmitted to
> the commmand.
> Thanks
> obsessive compulsive host processor command line
> [1191227014.189078] [2320.2] [pid=27028] Input:
> $USER2$/submit_check_result $HOSTNAME$ $HOSTSTATEID$ '$HOSTOUTPUT$'
> [1191227014.189091] [2320.2] [pid=27028] Output:
> [1191227014.189103] [016.2] [pid=27028] Raw obsessive compulsive host
> processor command line: $USER2$/submit_check_result $HOSTNAME$
> [1191227014.189116] [001.0] [pid=27028] process_macros()
> [1191227014.189128] [2048.1] [pid=27028] **** BEGIN MACRO PROCESSING
> [1191227014.189141] [2048.1] [pid=27028] Processing:
> '$USER2$/submit_check_result $HOSTNAME$ $HOSTSTATEID$ '$HOSTOUTPUT$''
> [1191227014.189153] [2048.2] [pid=27028] Processing part: ''
> [1191227014.189166] [2048.2] [pid=27028] Not currently in macro.
> Running output (0): ''
> [1191227014.189178] [2048.2] [pid=27028] Processing part: 'USER2'
> [1191227014.189195] [2048.2] [pid=27028] Cleaned macro. Running
> output (39): '/usr/local/nagios/libexec/eventhandlers'
> [1191227014.189208] [2048.2] [pid=27028] Just finished macro. Running
> [1191227014.189220] [2048.2] [pid=27028] Processing part:
> '/submit_check_result '
> [1191227014.189234] [2048.2] [pid=27028] Not currently in macro.
> Running output (60):
> '/usr/local/nagios/libexec/eventhandlers/submit_check_result '
> [1191227014.189247] [2048.2] [pid=27028] Processing part: 'HOSTNAME'
> [1191227014.189260] [2048.2] [pid=27028] Cleaned macro. Running
> output (68):
> '/usr/local/nagios/libexec/eventhandlers/submit_check_result U3RIPC85'
> [1191227014.189273] [2048.2] [pid=27028] Just finished macro. Running
> output (68):
> [1191227014.189286] [2048.2] [pid=27028] Processing part: ' '
> [1191227014.189327] [2048.2] [pid=27028] Not currently in macro.
> Running output (69):
> '/usr/local/nagios/libexec/eventhandlers/submit_check_result U3RIPC85 '
> [1191227014.189341] [2048.2] [pid=27028] Processing part: 'HOSTSTATEID'
> [1191227014.189355] [2048.2] [pid=27028] Cleaned macro. Running
> output (70):
> '/usr/local/nagios/libexec/eventhandlers/submit_check_result U3RIPC85 1'
> [1191227014.189368] [2048.2] [pid=27028] Just finished macro. Running
> output (70):
> [1191227014.189381] [2048.2] [pid=27028] Processing part: ' ''
> [1191227014.189394] [2048.2] [pid=27028] Not currently in macro.
> Running output (72):
> '/usr/local/nagios/libexec/eventhandlers/submit_check_result U3RIPC85 1 ''
> [1191227014.189407] [2048.2] [pid=27028] Processing part: 'HOSTOUTPUT'
> [1191227014.189422] [2048.2] [pid=27028] Cleaned macro. Running
> output (148):
> 'CRITICAL - 10.176.77.85: Host unreachable @ 10.176.77.57. rta nan, lost
> 100%'
> [1191227014.189435] [2048.2] [pid=27028] Just finished macro. Running
> output (148):
> 100%'
> [1191227014.189448] [2048.2] [pid=27028] Processing part: '''
> [1191227014.189462] [2048.2] [pid=
...[email truncated]...
