Not rescheduling notifications if outside valid timeperiod
- -fno-stack-protector
Re: Not rescheduling notifications if outside valid timeperi
Interesting to note, the logic we saw in the code, did not seem like it should present this issue. Could you post a bug on tracker.nagios.org please and link to this thread. It would also be helpful if you could put detailed test cases in for the developers.
sreinhardt, one thing though, before I submit a bug report: the code review was for version 3.2.3 or version 3.4.3?
It was for 3.5.1 actually, you should probably specify that, however the other thread I linked to was using 3.5 so it may be a continuing bug.
edit: the worst that happens, is it gets closed and not resolved for being an old version
Thank you! If anything changes you should be notified on the tracker page as well.
