Curl problem in Nagios core 3.5.1
cesar.garza
Post by cesar.garza »
Hey guys
I am facing a weird problem that i haven't seen it before. i used to had nagios 3.4.4 version and now i moved to nagios core 3.5.1. I moved all my customize scripts to new nagios and everything is working except one script(activemq). When i tested this script from command line, it gave me the response. However, when i hook it up with service.cfg and command.cfg, it throws the error like "null". I debug it and found this error curl: no URL specified! curl: try 'curl --help' or 'curl --manual' for more information.
script download it from :
http://exchange.nagios.org/directory/Pl ... or/details
ran the script from command line
command.cfg file
command.cfg file
Service.cfg file
Service.cfg file
Re: Curl problem in Nagios core 3.5.1
It looks like the plugin is trying to interpret "-a" as the URL. I didn't see any switches for that plugin. Is there a reason you have it included? Try removing it from the command_line entry in your config file and see if this works.
