Sources Not Start
mikew
Sources Not Start
Post by mikew »
Network Analyzer
I have installed the latest version on a CentOS 6.x. I have configured several sources but none of the sources will start. The error I see is this:
There was an error running nfdump command: /usr/local/bin/nfdump -M '/usr/local/nagiosna/var/centos/flows/' -R . -t '2013/10/27.06:17:03-2013/10/28.06:17:02' -N -n '5' -s 'srcip/bytes' -o 'csv' 2> /dev/null
Mike Weber
Nagios Training/Consulting
sreinhardt
-fno-stack-protector
Re: Sources Not Start
Post by sreinhardt »
Is this displayed on the webui when opening the source tab, or when running a query? Which version of NNA do you presently have installed?
mikew
Post by mikew »
The version is the latest 2014R1.1 and the message shows up in Network Analyzer in source/reports and the dashboard shows all sources are red not functioning.
I have installed again and receive the same error.
Mike Weber
nscott
Post by nscott »
Lets make see if its a UI bug:
ps aux | grep nfcapd
Is this showing any instances of nfcapd running? If yes, then we have UI bug, if not then lets delve deeper.
From the command line run
sh /usr/local/nagiosna/bin/nagiosna start
Does this give any error? If so, what is it? Otherwise, let us now consult the backend.log at /usr/local/nagiosna/var/backend.log.
Does anything show up there showing some kind of error? Lastly, is there anything in the /var/log/messages?
Nicholas Scott
mikew
Post by mikew »
Here is the output:
No instance running.
Traceback (most recent call last):
  File "/usr/local/nagiosna/bin/initialize_source.py", line 16, in <module>
    import rrdtool
ImportError: librrd.so.4: cannot open shared object file: No such file or directory
No such directory: /usr/local/nagiosna/var/nagiosxi/flows
stat() error /usr/local/nagiosna/var/nagiosxi/flows: No such file or directory
Failed to add default data collector directory
    import rrdtool
open() error on '/usr/local/nagiosna/var/centos/flows/.nfstat' in nfstatfile.c line 312: Permission denied
NagiosNA backend started...
tail /usr/local/nagiosna/var/backend.log
Could not start nfcapd listening on 8001 for source centos
Error running initialization.
Could not start nfcapd listening on 8000 for source nagiosxi
/var/log/messages
Oct 29 22:55:15 net nfcapd[27708]: Add extension: 2 byte input/output interface index
Oct 29 22:55:15 net nfcapd[27708]: Add extension: 4 byte input/output interface index
Oct 29 22:55:15 net nfcapd[27708]: Add extension: 2 byte src/dst AS number
Oct 29 22:55:15 net nfcapd[27708]: Add extension: 4 byte src/dst AS number
Oct 29 22:55:15 net nfcapd[27708]: Replay flows to host: 192.168.5.77 port: 8001
Oct 29 22:55:15 net nfcapd[27710]: Error opening pid file: '/usr/local/nagiosna/var/centos/8001.pid' Permission denied
Mike Weber
Mike,
Run the following command, and show the output:
which rrdtool
What is the rrdtool version? Do you have any PID files in "/usr/local/nagiosna/var/centos/"? If you do, you can delete them, and try again running:
mikew
Post by mikew »
which rrdtool
/usr/local/bin/rrdtool
There is no centos directory in /usr/local/nagiosna
only backend,bin,etc,var
I have set up several sources and none of them have directories created.
Mike Weber
sreinhardt
Can you send us a the portion of the sudoers file that contains nna lines, it might be in the /etc/sudoers.d/ directory as well. At the same time, just to confirm, what are the permissions inside /usr/local/nagiosna/?
mikew
Post by mikew »
Here is the sudo permissions
Defaults:%nnacmd !requiretty
Cmnd_Alias LIST = /sbin/iptables --list
Cmnd_Alias SAVE = /etc/init.d/iptables save
Cmnd_Alias UPDATE = /sbin/iptables -I INPUT -p udp -j ACCEPT --dport *
Cmnd_Alias DAEMON = /usr/local/nagiosna/bin/nagiosna *
%nnacmd ALL=(ALL) NOPASSWD:LIST
%nnacmd ALL=(ALL) NOPASSWD:SAVE
%nnacmd ALL=(ALL) NOPASSWD:UPDATE
%nnacmd ALL=(ALL) NOPASSWD:/bin/kill *
%nnacmd ALL=(ALL) NOPASSWD:DAEMON
RRDtool 1.4.8 Copyright 1997-2013 by Tobias Oetiker <[email protected]>
Compiled Oct 29 2013 03:37:52
Mike Weber
