Hi, I’m new to forum, working on a nagios issue at my office. I am using check_snmp to grab multiple OID values at one time, as follows in example:
./check_snmp –H 1.1.1.1 –C public –o ‘<OID1>,<OID2>,…<OIDn>’ –u ‘<Label1>,<Label2>,…<Labeln>’
It seems that there is some sort of string limit on the number of OIDS or labels I can collect with one query. After about 4 (n=5,6,7,…), the query returns junk text. Is there a newer version of check_snmp that doesn’t have this issue? Or a way to get around this? Im using this version:
-rwxr-xr-x 1 root root 162576 Aug 17 2012 check_snmp
Thx in advance,
Will
check_snmp doesnt takes long argument strings...
[email protected]
