Nagios consuming memory
Helio
Post by Helio »
I have an Ubuntu 10.10, and Nagios 3.5.1, and MKlivestatus. At the beginning my ram memory has nearly 50% free (I have 1GB ram). But, day by day, the memory is been consumed. After 5 days working, my system has only 10% memory free, and swap starts working logically. How Nagios increase the use of ram memory? Nagios are sending pings and snmpget commands to 44 different machines (no one are accesible, it´s a test). Why continue consuming memory? Is a problem with MKLivestatus?
Thank you in advanced.
Helio.-
Re: Nagios consuming memory
Can you run the "top" command and post a screenshot or the actual output?
abrist
Red Shirt
Post by abrist »
Helio wrote:Is a problem with MKLivestatus?
Possibly. What does the ram usage look like? What process name is mostly to blame? Are the nagios forks for checks hanging?
ps -aux
Helio
Post by Helio »
This is a screenshot
A top screenshot
A top screenshot
Post by slansing »
When you restart nagios does your unassigned memory reset to a more suitable number?
Helio
Post by Helio »
When I restart Nagios, memory goes from 164KB free to 262kB free, but at the begining my system had 500KB free. Day by day my memory continues reducing my free memory. I attach two snapshot, one before de restart Nagios, and the other after restart Nagios.
It should be the use of mklivestatus...
Thank in advanced.
Helio.-
Helio
Post by Helio »
And this is the snapshot after restart...
abrist
Red Shirt
Post by abrist »
Lets check the amount of ram that is used for disk buffers:
free -m
Could you also run:
ps -aux
Helio
Post by Helio »
After 7 days working I did your commented command: free -m
As you can see I think I´m losing buffers day by day (or is not used).
Thank you.
Helio.-
Free Memory.png (4.48 KiB) Viewed 3517 times
abrist
Red Shirt
Post by abrist »
It looks like you only have around 200mbs free after buffers. It the server load/memory spikes, you start using swap. Can you increase the provisioned ram for this vm?
