Hi ,
tmcdonald thanks for reply.
i try to modify the this script after suceesful i will post it.
check_cisco_ping
Re: check_cisco_ping
Sounds good. I will keep this topic open until you return. Please only post once you have the script, otherwise this will go into our "TODO" queue.
