nagios_mail.php
nagios_mail.php
command_name notify-host-by-email
command_line /usr/bin/printf "%b" "***** Nagios *****\n\nNotification Type: $NOTIFICATIONTYPE$\nHost: $HOSTNAME$\nState: $HOSTSTATE$\nAddress: $HOSTADDRESS$\nInfo: $HOSTOUTPUT$\n\nDate/Time: $LONGDATETIME$\n" | /bin/mail -s "** $NOTIFICATIONTYPE$ Host Alert: $HOSTNAME$ is $HOSTSTATE$ **" $CONTACTEMAIL$
command_line /usr/bin/printf "%b" "***** Nagios *****\n\nNotification Type: $NOTIFICATIONTYPE$\n\nService: $SERVICEDESC$\nHost: $HOSTALIAS$\nAddress: $HOSTADDRESS$\nState: $SERVICESTATE$\n\nDate/Time: $LONGDATETIME$\n\nAdditional Info:\n\n$SERVICEOUTPUT$\n" | /bin/mail -s "** $NOTIFICATIONTYPE$ Service Alert: $HOSTALIAS$/$SERVICEDESC$ is $SERVICESTATE$ **" $CONTACTEMAIL$
<?php
* Extended Nagios Notification Mail
* Version 0.9
* Install:
* replace the notifying definitions in the misccomands.cfg. Make sure that PHP
* is installed and the path to the PHP-binary is correct.
* # Example misccommands.cfg
* define command{
* command_name host-notify-by-email
* command_line /usr/bin/php -q /opt/nagios_mail.php
* define command{
* command_name notify-by-email
* Configuration:
* configure your domain address below in this file.
* @author Otto Berger <otto@bergerdata.de>
* @copyright Copyright (c) 2009, Otto Berger
* @license http://opensource.org/licenses/lgpl-license.php GNU Lesser General Public License
* @version $Id: nagios_mail.php 10 2009-10-28 10:37:46Z otto $
// CONFIGURATION
* Nagios url
* url to your nagios webinterface. Used for command-links inside the mail.
$config['nagios_url'] = 'http://example.com/nagios';
* From-address of the notification mail
$config['mail_from_address'] = 'monitoring@example.com';
* additional to mail-to-address
* this address is also used as reciepient while using the test-mode
* from command-line (and not run from nagios)
$config['mail_add_to_address'] = '';
* mail-subject template (host notification)
* you can use all Nagios-vars here, see example
$config['mail_subject_host'] = '[M] Host %%NOTIFICATIONTYPE%% %%HOSTNAME%% is %%HOSTSTATE%% (%%NOTIFICATIONNUMBER%%)';
* mail-subject template (service notification)
$config['mail_subject_service'] = '[M] Service %%NOTIFICATIONTYPE%% %%HOSTNAME%% %%SERVICEDESC%% is %%SERVICESTATE%% (%%NOTIFICATIONNUMBER%%)';
* additional mail-headers
* adds additional header-lines to the mail header. In this example
* uncomment the following lines to send outlook high-priority mails.
$config['mail_add_headers'] = array(
//'X-Priority: 1 (Highest)',
//'X-MSMail-Priority: High',
//'Importance: High',
* debug mode
* enables the debug mode. All variables sent from nagios are printed at the end
* of the mail. Attention: only visible in the text-only variant of the mail!
$config['debug'] = false;
* Advanced configuration of mail bodies
* experts only ;)
* customize the view of the nagios-variables.
// HOST DETAILS
$config['groups'][] = array(
'name' => 'Host details',
'active' => true,
'branches' => array(
array(
'name' => 'Host Informations',
'active' => true,
'data' => array(
array(
'name' => 'Hostname',
'nagios_env' => 'HOSTNAME',
'required' => true,
array(
'name' => 'Alias',
'nagios_env' => 'HOSTALIAS',
'required' => false,
array(
'name' => 'Address',
'nagios_env' => 'HOSTADDRESS',
'required' => true,
'type' => 'link',
array(
'name' => 'Description',
'nagios_env' => 'HOSTNOTES',
array(
'name' => 'URL',
'nagios_env' => 'HOSTNOTESURL',
'type' => 'link',
array(
'name' => 'Host State',
'active' => true,
'data' => array(
array(
'name' => 'State',
'nagios_env' => 'HOSTSTATE',
array(
'name' => 'State-Type',
'nagios_env' => 'HOSTSTATETYPE',
array(
'name' => 'Attempt',
'nagios_env' => 'HOSTATTEMPT',
array(
'name' => 'Duration',
'nagios_env' => 'HOSTDURATION',
array(
'name' => 'Downtime',
'nagios_env' => 'HOSTDOWNTIME',
array(
'name' => 'Host Group',
'active' => true,
'data' => array(
array(
'name' => 'Group',
'nagios_env' => 'HOSTGROUPNAME',
array(
'name' => 'Group Alias',
'nagios_env' => 'HOSTGROUPALIAS',
array(
'nagios_env' => 'HOSTGROUPNOTES',
array(
'nagios_env' => 'HOSTGROUPNOTESURL',
'type' => 'link',
array(
'name' => 'Host-Acknowledgement',
'active' => true,
'data' => array(
array(
'name' => 'Author',
'nagios_env' => 'HOSTACKAUTHOR',
array(
'name' => 'Comment',
'nagios_env' => 'HOSTACKCOMMENT',
array(
'name' => 'Host State Data',
'active' => true,
'data' => array(
array(
'name' => 'Command',
'nagios_env' => 'HOSTCHECKCOMMAND',
array(
'name' => 'Type',
'nagios_env' => 'HOSTCHECKTYPE',
array(
'name' => 'Latency',
'nagios_env' => 'HOSTLATENCY',
array(
'name' => 'Percentage',
'nagios_env' => 'HOSTPERCENTAGE',
array(
'name' => 'Host-Output',
'active' => true,
'data' => array(
array(
'name' => false,
'nagios_env' => 'HOSTOUTPUT',
array(
'name' => 'Host Times',
'active' => true,
'data' => array(
array(
'name' => 'Last Check',
'nagios_env' => 'LASTHOSTCHECK',
'type' => 'timestamp',
array(
'name' => 'Last State-Change',
'nagios_env' => 'LASTHOSTSTATECHANGE',
array(
'name' => 'Last Up',
'nagios_env' => 'LASTHOSTUP',
array(
'name' => 'Last Down',
'nagios_env' => 'LASTHOSTDOWN',
array(
'name' => 'Last Unrechable',
'nagios_env' => 'LASTHOSTUNREACHABLE',
// SERVICE DETAILS
'name' => 'Service details',
'active' => true,
array(
'name' => 'Servive details',
'active' => true,
'data' => array(
array(
'name' => 'Service',
'nagios_env' => 'SERVICEDESC',
array(
'nagios_env' => 'SERVICECHECKCOMMAND',
array(
'name' => 'Type',
'nagios_env' => 'SERVICECHECKTYPE',
array(
'nagios_env' => 'SERVICELATENCY',
array(
'nagios_env' => 'SERVICEPERCENTCHANGE',
array(
'name' => 'Service Group',
'active' => true,
'data' => array(
array(
'name' => 'Group',
'nagios_env' => 'SERVICEGROUPNAME',
array(
'nagios_env' => 'SERVICEGROUPALIAS',
array(
'name' => 'Notes',
'nagios_env' => 'SERVICEGROUPNOTES',
array(
'name' => 'Notes',
'nagios_env' => 'SERVICEGROUPNOTESURL',
'type' => 'link',
array(
'name' => 'Service-Acknowledgement',
'active' => true,
'data' => array(
array(
'name' => 'Author',
'nagios_env' => 'SERVICEACKAUTHOR',
array(
'nagios_env' => 'SERVICEACKCOMMENT',
array(
'name' => 'Service State',
'active' => true,
'data' => array(
array(
'name' => 'State',
'nagios_env' => 'SERVICESTATE',
array(
'nagios_env' => 'SERVICESTATETYPE',
array(
'nagios_env' => 'SERVICEATTEMPT',
array(
'nagios_env' => 'SERVICEDURATION',
array(
'nagios_env' => 'SERVICEDOWNTIME',
array(
'name' => 'Service-Output',
'active' => true,
'data' => array(
array(
'name' => false,
'nagios_env' => 'SERVICEOUTPUT',
array(
'name' => 'Service Times',
'active' => true,
'data' => array(
array(
'nagios_env' => 'LASTSERVICECHECK',
array(
'nagios_env' => 'LASTSERVICESTATECHANGE',
array(
'name' => 'Last OK',
'nagios_env' => 'LASTSERVICEOK',
array(
'name' => 'Last Critical',
'nagios_env' => 'LASTSERVICECRITICAL',
array(
'name' => 'Last Warning',
'nagios_env' => 'LASTSERVICEWARNING',
array(
'name' => 'Last Unknown',
'nagios_env' => 'LASTSERVICEUNKNOWN',
// CONTACT DETAILS
'name' => 'Contact details',
'active' => true,
array(
'name' => 'Contact Info',
'active' => true,
'data' => array(
array(
'name' => 'Name',
'nagios_env' => 'CONTACTNAME',
array(
'name' => 'Alias',
'nagios_env' => 'CONTACTALIAS',
array(
'name' => 'eMail',
'nagios_env' => 'CONTACTEMAIL',
'type' => 'mail',
array(
'name' => 'Pager',
'nagios_env' => 'CONTACTPAGER',
array(
'name' => 'Contactgroup Info',
'active' => true,
'data' => array(
array(
'name' => 'Name',
'nagios_env' => 'CONTACTGROUPNAME',
array(
'name' => 'Alias',
'nagios_env' => 'CONTACTGROUPALIAS',
array(
'name' => 'Members',
'nagios_env' => 'CONTACTGROUPMEMBERS',
// STATISTICS
'name' => 'Statistics',
'active' => true,
array(
'name' => 'Hosts-Totals',
'active' => true,
'data' => array(
array(
'name' => 'Problems',
'nagios_env' => 'TOTALHOSTPROBLEMS',
array(
'name' => 'Problems Unhandled',
'nagios_env' => 'TOTALHOSTPROBLEMSUNHANDLED',
array(
'name' => 'Down',
'nagios_env' => 'TOTALHOSTSDOWN',
array(
'name' => 'Down Unhandled',
'nagios_env' => 'TOTALHOSTSDOWNUNHANDLED',
array(
'name' => 'Unreachable',
'nagios_env' => 'TOTALHOSTSUNREACHABLE',
array(
'name' => 'Unreachable Unhandled',
'nagios_env' => 'TOTALHOSTSUNREACHABLEUNHANDLED',
array(
'name' => 'Up',
'nagios_env' => 'TOTALHOSTSUP',
array(
'name' => 'Services-Totals',
'active' => true,
'data' => array(
array(
'nagios_env' => 'TOTALSERVICEPROBLEMS',
array(
'nagios_env' => 'TOTALSERVICEPROBLEMSUNHANDLED',
array(
'name' => 'Critical',
'nagios_env' => 'TOTALSERVICESCRITICAL',
array(
'name' => 'Critical Unhandled',
'nagios_env' => 'TOTALSERVICESCRITICALUNHANDLED',
array(
'name' => 'Unknown',
'nagios_env' => 'TOTALSERVICESUNKNOWN',
array(
'name' => 'Unknown Unhandled',
'nagios_env' => 'TOTALSERVICESUNKNOWNUNHANDLED',
array(
'name' => 'Warning',
'nagios_env' => 'TOTALSERVICESWARNING',
array(
'name' => 'Warning Unhandled',
'nagios_env' => 'TOTALSERVICESWARNINGUNHANDLED',
array(
'name' => 'OK',
'nagios_env' => 'TOTALSERVICESOK',
class Nagios_Mail {
var $config = array();
var $nagios = array();
var $replace = array();
var $notification_type;
var $notification_color;
function setConfig($config) {
$this->config = (array)$config;
function __construct() {
foreach ($_ENV as $key => $value) {
if (strpos($key, 'NAGIOS_') !== false) {
$this->nagios[substr($key, 7)] = $value;
$this->replace['%%' . substr($key, 7) . '%%'] = $value;
function build() {
if (!empty($this->nagios['SERVICECHECKTYPE'])) {
$this->notification_type = 'SERVICE';
if (!empty($this->nagios['SERVICEACKAUTHOR'])) {
$this->notification_type = 'SERVICE_ACK';
} else {
$this->notification_type = 'HOST';
if (!empty($this->nagios['HOSTACKAUTHOR'])) {
$this->notification_type = 'HOST_ACK';
$this->str_info = '';
if (!count($this->nagios)) {
// Test-Mode
foreach ($this->config['groups'] as $group) {
foreach ($group['branches'] as $branch) {
foreach ($branch['data'] as $field) {
if (!isset($field['type'])) {
$field['type'] = false;
if ($field['type'] == 'timestamp') {
$value = time();
} else {
$value = $field['nagios_env'];
$this->nagios[$field['nagios_env']] = (strlen($value) > 17) ? substr($value, 0, 17) . "..." : $value;
$this->str_info .= ' TESTMODE: ';
$this->nagios['CONTACTEMAIL'] = '';
$this->nagios['NOTIFICATIONTYPE'] = '';
$this->nagios['NOTIFICATIONNUMBER'] = '';
if (!empty($this->nagios['CONTACTEMAIL']) || $this->config['mail_add_to_address']) {
switch($this->notification_type) {
case 'HOST' :
case 'HOST_ACK' :
$this->str_info .= strtr($this->config['mail_subject_host'], $this->replace);
switch ($this->nagios['HOSTSTATE']) {
case 'UP' :
$this->notification_color = '#00CC33'; // green
break;
case 'DOWN' :
$this->notification_color = '#FF0000'; // red
break;
case 'UNREACHABLE' :
break;
default :
$this->notification_color = '#999999'; // grey
break;
break;
case 'HOST_ACK' :
$this->str_info .= 'ACK FROM ' . $this->nagios['HOSTACKAUTHOR'];
break;
case 'SERVICE' :
case 'SERVICE_ACK' :
$this->str_info .= strtr($this->config['mail_subject_service'], $this->replace);
switch ($this->nagios['SERVICESTATE']) {
case 'OK' :
break;
case 'WARNING' :
$this->notification_color = '#FF6600'; // orange
break;
break;
case 'CRITICAL' :
break;
case 'UNKNOWN' :
default :
break;
break;
$this->str_info .= 'ACK FROM ' . $this->nagios['SERVICEACKAUTHOR'];
break;
$info_types = array(
'ACKNOWLEDGEMENT',
'FLAPPINGSTART',
'FLAPPINGSTOP',
'FLAPPINGDISABLED',
'DOWNTIMESTART',
'DOWNTIMEEND',
'DOWNTIMECANCELLED',
if (in_array($this->nagios['NOTIFICATIONTYPE'], $info_types)) {
$this->notification_color = 'blue';
$boundary = '----------_' . md5('Nagios_Mail_' . microtime());
$headers = array();
$headers[] = 'MIME-Version: 1.0';
$headers[] = 'From: ' . $this->config['mail_from_address'];
foreach ($this->config['mail_add_headers'] as $header) {
$headers[] = $header;
$headers[] = "Content-Type: multipart/alternative;\n boundary=\"" . $boundary . "\"";
$body = "\n--" . $boundary . "\nContent-Transfer-Encoding: 8bit\nContent-Type: text/plain; charset=ISO-8859-15\n\n";
$body .= $this->getBodyText();
$body .= "\n--" . $boundary . "\nContent-Transfer-Encoding: 8bit\nContent-Type: text/html; charset=ISO-8859-15\n\n";
$body .= $this->getBodyHTML();
$body .= "\n--" . $boundary . "--\n";
if ($this->nagios['CONTACTEMAIL'] && $this->config['mail_add_to_address']) {
$this->nagios['CONTACTEMAIL'] .= ', ' . $this->config['mail_add_to_address'];
} elseif (empty($this->nagios['CONTACTEMAIL'])) {
$this->nagios['CONTACTEMAIL'] = $this->config['mail_add_to_address'];
mail($this->nagios['CONTACTEMAIL'], $this->str_info, $body, implode("\n", $headers));
} else {
die("\nCONTACTEMAIL env-var is empty (not run from Nagios?) or 'mail_add_to_address' not configured (Testmode)\n\n");
function getBodyText() {
$output_text[] = $this->str_info;
if (strpos($this->notification_type, 'HOST') !== false) {
$output_text[] = '*Output*: ' . $this->nagios['HOSTOUTPUT'];
} else {
$output_text[] = '*Output*: ' . $this->nagios['SERVICEOUTPUT'];
$output_text[] = '';
if (!$group['active'] || $group['active'] != $this->notification_type) {
continue;
$group_text = array();
if (!$branch['active'] || $branch['active'] != $this->notification_type) {
continue;
$branch_active = false;
$max_chars = 0;
foreach ($branch['data'] as $value) {
if (strlen($value['name']) > $max_chars && (!empty($this->nagios[$value['nagios_env']]) || $value['required']) || (!empty($this->nagios[$value['nagios_env']]) && empty($value['name']))) {
$max_chars = strlen($value['name']);
$branch_active = true;
if ($branch_active) {
$group_text[] = '*' . $branch['name'] . '*';
$field['value'] = trim($this->nagios[$field['nagios_env']]);
if (!empty($field['value']) || $field['required']) {
switch($field['type']) {
case 'timestamp' :
$field['value'] = date('d.m.Y H:i', $field['value']);
break;
if ($field['name']) {
$group_text[] = sprintf('%-'. ($max_chars+1) . 's: %s', $field['name'], $field['value']);
} else {
$group_text[] = $field['value'];
$group_text[] = '';
if (count($group_text)) {
$output_text[] = '*' . $group['name'] . '*';
$output_text[] = '------------------------------------';
$output_text[] = implode("\n", $group_text);
if ($this->config['nagios_url']) {
$output_text[] = '/Nagios/:';
$output_text[] = '<' . $this->config['nagios_url'] . '>';
if ($this->notification_type == 'HOST' && $this->nagios['NOTIFICATIONTYPE'] == 'PROBLEM') {
$output_text[] = '/Acknowledge this problem/:';
$output_text[] = '<' . $this->config['nagios_url'] . '/cgi-bin/cmd.cgi?cmd_typ=33&host=' . $this->nagios['HOSTNAME'] . '>';
} elseif ($this->notification_type == 'SERVICE' && $this->nagios['NOTIFICATIONTYPE'] == 'PROBLEM') {
$output_text[] = '<' . $this->config['nagios_url'] . '/cgi-bin/cmd.cgi?cmd_typ=34&host=' . $this->nagios['HOSTNAME'] . '&service=' . $this->nagios['SERVICEDESC'] . '>';
if ($this->config['debug']) {
ksort($this->nagios);
ob_start();
var_dump($this->nagios);
$output_text[] = "*DEBUG-OUTPUT*";
$output_text[] = ob_get_clean();
return implode("\n", $output_text);
function getBodyHTML() {
$output_html[] = <<< END
<!DOCTYPE html PUBLIC "-//W3C//DTD XHTML 1.0 Transitional//EN" "http://www.w3.org/TR/xhtml1/DTD/xhtml1-transitional.dtd">
<html xmlns="http://www.w3.org/1999/xhtml">
<head>
<title></title>
<meta http-equiv="Content-Type" content="text/html; charset=iso-8859-15" />
<meta name="viewport" content="width=600" />
</head>
<body style="font-family: 'Courier New', Courier, monospace; font-size: 8pt;">
END;
$output_html[] = '<table cellpadding="0" cellspacing="0" width="100%" style="font-family: \'Courier New\', Courier, monospace; font-size: 8pt;">';
$output_html[] = '<tr>';
$output_html[] = '<td width="16"><div style="height:16px;width:16px;background-color:' . $this->notification_color . ';"> </div></td>';
$output_html[] = '<td style="font-size:15pt;font-weight:bold;color:#666666;padding-left:4px">Nagios Monitoring Message</td>';
$output_html[] = '</tr>';
$output_html[] = '</table>';
$output_html[] = '<div style="background-color:#CCC;padding:5px;clear:both;">';
$output_html[] = '<div style="font-weight:bold;">';
$output_html[] = $this->str_info;
$output_html[] = '</div>';
$output_html[] = '<div style="margin-bottom:10px;">';
$output_html[] = '<strong>Output:</strong> ' . $this->nagios['HOSTOUTPUT'];
} else {
$output_html[] = '<strong>Output:</strong> ' . $this->nagios['SERVICEOUTPUT'];
$output_html[] = '<div>';
$output_html[] = '<a href="' . $this->config['nagios_url'] . '">' . $this->config['nagios_url'] . '</a>';
$output_html[] = ' | <a href="' . $this->config['nagios_url'] . '/cgi-bin/cmd.cgi?cmd_typ=33&host=' . $this->nagios['HOSTNAME'] . '">Acknowledge this problem</a>';
$output_html[] = ' | <a href="' . $this->config['nagios_url'] . '/cgi-bin/cmd.cgi?cmd_typ=34&host=' . $this->nagios['HOSTNAME'] . '&service=' . $this->nagios['SERVICEDESC'] . '">Acknowledge this problem</a>';
continue;
$group_html = array();
continue;
$max_chars = 0;
$branch_html = array();
$branch_html[] = '<table cellspacing="0" cellpadding="0" width="280" style="border:1px solid #CFCFCF; font-family: \'Courier New\', Courier, monospace; font-size: 8pt;">';
$branch_html[] = '<thead style="font-weight:bold; color:#003399; background-color:#CFCFCF;"><tr><td colspan="2">' . $branch['name'] . '</td></tr></thead>';
$branch_html[] = '<tbody>';
case 'timestamp' :
break;
case 'link' :
if (strpos($field['value'], 'http://') === false) {
$field['value'] = sprintf('<a href="http://%s">%s</a>', $field['value'], $field['value']);
} else {
$field['value'] = sprintf('<a href="%s">%s</a>', $field['value'], $field['value']);
break;
case 'mail' :
$field['value'] = sprintf('<a href="mailto:%s">%s</a>', $field['value'], $field['value']);
break;
$branch_html[] = sprintf('<tr><td style="padding:1px 2px 1px 2px;width:120px; font-weight:bold;">%s</td><td>%s</td></tr>', $field['name'], $field['value']);
} else {
$branch_html[] = sprintf('<tr><td style="padding:1px 2px 1px 2px;" colspan="2">%s</td></tr>', $field['value']);
$branch_html[] = '</tbody>';
$branch_html[] = '</table>';
$branch_html[] = '';
$group_html[] = implode("\n", $branch_html);
if (count($group_html)) {
$output_html[] = '<h2 style="font-size:10pt;font-weight:bold;color:#666666;border-bottom:1px solid #CCCCCC;clear:both;margin-top:15px;">' . $group['name'] . '</h2>';
$output_html[] = '<table width="100%" cellpadding="0" cellspacing="0">';
if (count($group_html) % 2 !== 0) {
$group_html[] = "";
foreach ($group_html as $i => $html) {
if ($i % 2 == 0) {
if ($i != 0){
$output_html[] = '<td ' . (($i % 2 == 0) ? 'width="285" ' : '') . 'valign="top" align="left" style="padding: 0 0 5px 0">' . $html . '</td>';
$output_html[] = '</body></html>';
return implode("\n", $output_html);
$nagios = new Nagios_Mail();
$nagios->setConfig($config);
$nagios->build();
