SSL and Email issues with nagios
Re: SSL and Email issues with nagios
So I think this is what's going on ... the html email notification was expecting env variables but the new nagios doesn't do that, even when enabled.
that is definitely the problem them.
On that tracker post would ryanhoskin's posted solution be a temporary fix for you? I believe that this is being worked on right now.
The command is listed like this:
Looking at the .php file, I don't think I can edit it to include/change the variables.
command_line /usr/bin/php -q /u01/app/nagios/bin/nagios_mail.php
- -fno-stack-protector
I may have missed it, but could you link to or post that php file please? If you are using core 4 and the script is expecting environmental variables, lmiltchevs comment would definitely match the issue.
I am actually using another script that does not require env variables, it has enough of what I need ... and I was able to add in a few funky links I needed... thanks all, we can close this.
