Hi all,
i have some problems that i cant find solution for it. I have 10 PC/Server hosts and for i dont know what reason, on one or two hosts i get this "Connection refused" status. Every 10 hosts are the same conf. (except the ip and hostname of course), all other hosts working ok and all the hosts have installed and configure the same NSClient++ same community etc. Also when i go to this two hosts that i get this connection refused (Host State Information) i get all OK but it shows me different i get mails that it is down ...
Also i try from the command to execute check_nt with different port numbers (just in case that it is not the port problem) and i got the same output ....
[root@mpnagios libexec]# ./check_nt -H 192.168.1.2 -p 12489 -s Testcomm -v CPULOAD -w 80 -c 90 -l 5,80,90,10,80,90
Connection refused
could not fetch information from server
[root@mpnagios libexec]# ./check_nt -H 192.168.1.3 -p 1248 -s Testcomm -v CPULOAD -w 80 -c 90 -l 5,80,90,10,80,90
Connection refused
Starting Nmap 5.51 ( http://nmap.org ) at 2013-12-02 14:49 CET
Nmap scan report for 192.168.17.1
Host is up (0.011s latency).
PORT STATE SERVICE
12489/tcp closed unknown
Nmap done: 1 IP address (1 host up) scanned in 0.06 seconds
[root@mpnagios objects]#
is this port closed from nagios side ( CentOS default Firewall ) or from the address ( the pc that i want to monitor ) ? And interesting that all other hosts work on the same port number and it is ok ... just this two of them ...
