[SOLVED] Performance Graph text is gibberish
dmartin
Post by dmartin »
- NagiosXI
- CentOS 6.4 Minimal Virtual Machine running on KVM
- Fresh install with checks from another CentOS 6.4 virtual machine via nrpe.
Performance graphs appear to be working (they have data), but the graph text is gibberish. Has anyone saw this before, and now how to correct?
Attached is the image:
Re: [SOLVED] Performance Graph text is gibberish
Is your issue actually solved? If so, what was the problem?
