i believe this is a bug, anyway, maybe there is an idea for an workaround or an hint on what i am doing wrong:
Following problem:
if i write the output of an service- plugin to nagios.cmd, the output is not spitted into the two parts: SERVICEOUTPUT and LONGSERVICEOUTPUT.
The same plugin working as active check shows the output as expected.
Attached you'll see the screenshot of an example.
- the output 1. line is the active_check result
- the 2. line came from passive check
Thanks for every idea.
Passive Checks with LONGTEXT not shown correctly
hoschmieder
Re: Passive Checks with LONGTEXT not shown correctly
Can you show us the active and passive service check command definitions?
hoschmieder
Hi, thanks for your feedback. Unfortunaly i saw it right now.
I wrote a short test script to show you whats wrong. (see below)
In the attached picture you'll find the output.
There you see, that while active check puts the 2++ lines into the long output, the passive check puts all them together.
Any ideas ?
Holger
file: /etc/nagios/test_passive.pl
#!/usr/bin/perl
use strict;
use warnings;
use Getopt::Std;
my $nagcmd="/var/nagios/rw/nagios.cmd";
our($opt_H,$opt_T);
getopts('H:T:');
my $host=$opt_H;
my $checktyp=$opt_T;
my $servicename="Test ".$opt_T;
my $status="0";
my $outtext="Testcheck [OK] This is a test-check";
my $longout="Line 1\nLine 2\nLine 3";
my $perfdata=" | result=10;70;70; ";
if($checktyp eq "passive"){
my $outp="[".time()."] PROCESS_SERVICE_CHECK_RESULT;$host;$servicename;$status;$outtext";
$longout=~s/\n/\\n/g;
$outp.="\\n$longout $perfdata";
print $outp;
open(CM,">>".$nagcmd);
print CM $outp."\n";
close CM;
exit $status;
}elsif($checktyp eq "active"){
print "$outtext\n$longout $perfdata \n";
exit $status;
}else{
print "please choose ether -T active OR -T passive\n";
file: /etc/nagios/test1.cfg
command_name test_check
command_line /etc/nagios/test_passive.pl -H $HOSTADDRESS$ -T $ARG1$
define host {
max_check_attempts 4
check_command check_host_alive
active_checks_enabled 1
host_name nagios-Server
address 2.2.0.15
passive_checks_enabled 1
contact_groups Mailsystem_SCHMIEDER
active_checks_enabled 0
use 4Stunden
service_description Test passive
name Test passive
check_command test_check!passive
use 4Stunden
passive_checks_enabled 0
service_description Test aktive
name Test active
check_command test_check!active
Any ideas ?
Holger
#!/usr/bin/perl
use strict;
use warnings;
use Getopt::Std;
our($opt_H,$opt_T);
getopts('H:T:');
my $host=$opt_H;
my $status="0";
print $outp;
close CM;
exit $status;
exit $status;
}else{
define host {
address 2.2.0.15
use 4Stunden
name Test passive
use 4Stunden
name Test active
This is most likely a bug. What version of nagios core are you running?
hoschmieder
we are running 4.0.2.
same we saw also with 4.0.1
This is a bug. Please open up a bug report at: http://tracker.nagios.org
hoschmieder
the bug report is still opened: http://tracker.nagios.org/view.php?id=543
Great. The bug will get updated on the tracker, so that is the best place to follow it progress.
