no job control in this shell as a warning return
vivithemage
Post by vivithemage »
A linux server of ours is returning warning:
System call sent warnings to stderr: bash: no job control in this shell
this is for: Total Processes otherwise the server is monitored correctly and not returning any errors. The server is running CentOS 5.10...where do I find out what is spitting that error message out? The box has been up 265 days, I was thinking a reboot might be the best way to start troubleshooting.
abrist
Red Shirt
Re: no job control in this shell as a warning return
Post by abrist »
Are you using job control in the plugin script? (backgrounding, pausing processes, etc) If so, this is usually not allowed.
vivithemage
What does that call look like?
sreinhardt
-fno-stack-protector
Post by sreinhardt »
Why don't we go the route of, what plugin are you using that has this issue? Do you have a link, or can attach it here?
vivithemage
attached is the .cfg file that is read by nagios.
Looks like we are using:
Let me know if I should include anything else.
To me it looks like this call:
check_nrpe!check_local_procs!250!400!RSZDT
is the problem? mh419 is not having an issue, only the device mh409.
cpanel.cfg
(5.39 KiB) Downloaded 507 times
abrist
Red Shirt
Post by abrist »
Can you post a copy of the check_local_procs plugin?
vivithemage
# 'check_local_procs' command definition
        command_name    check_local_procs
        command_line    $USER1$/check_procs -w $ARG1$ -c $ARG2$ -s $ARG3$
abrist
Red Shirt
Post by abrist »
This is most likely a problem with a configuration setting on the remote system. Do you have any particular security setup? selinux, disabletty in /etc/sudoers, etc?
vivithemage
abrist wrote:This is most likely a problem with a configuration setting on the remote system. Do you have any particular security setup? selinux, disabletty in /etc/sudoers, etc?
Well, it was working ... and just started alerting.
selinux disabled
I see no reference to disabletty in the sudoers file either!
abrist
Red Shirt
Post by abrist »
How about /sbin/nologin in /etc/passwd? (Though this should not matter)
What has changed since it was last working?
