NagiosNA not integrating with NagiosXI
balothia
Post by balothia »
Hi All,
We are running nagiosxi and nagiosna on same VM. NagiosNA installation went fine, I added the source and started capturing data, all went fine. Now I am trying to integrate NagiosNA to XI, I have added the NRDP address and NNA has accepted it. But when I am trying to add the service it gives me error message “Cannot connect to NagiosXI component”.
Gautam
Re: NagiosNA not integrating with NagiosXI
Post by slansing »
Are you using the correct token? It is case sensitive. Also, are you using the correct address given in Admin > Inbound Transfers > NRDP?
balothia
Post by balothia »
Thanks for your reply... Yes all values are correct. Still for reference I am attaching the screen shots for reference.
Download the file below:
nagiosna.zip
Install the Nagios NA component in XI by going to: Admin->Manage Components->Browse->nagiosna.zip->Upload Component. Next, find the "Nagios Network Analyzer Component" in the list, and click on the "Edit Settings" button, type the Nagios NA's IP address in the "Allowed Host" file, select the "Enable Integration" tick button, and click on "Apply Settings".
After the component is installed, go back to the Nagios NA and try to add new Service/Hostname.
Let me know if this fixed your issue.
balothia
Post by balothia »
Thanks... This has resolved our issue of Integrating the NNA.
