I am glad we are finally getting somewhere.But at the prompt they show the correct time as UTC only... so that's my issue.
data time issue or query issue
Re: data time issue or query issue
Yes I would think so. I don't want to send you on a wild goose chase, but perhaps give this blog a try?
http://g300nh.blogspot.com/2010/06/set- ... -time.html
Nicholas Scott
Thanks for the link... and yes, I have figured out that it is ODD. I have some Ciscos which I will setup when I build my real naa server (got my key yesterday). The wrt is a drop-in probe I am using. So I just decided to turn off ntp and use local time, since it's really temporary and testing. But sure enough, no matter how I setup the clock, the rflow is presented in one format while the clock displays and logs use another.
I like this naa stuff. Is there going to be any groups, along with user security to allow access to only certain devices??
Glad you like it! As far as those features, they are excellent idea and could be included, but I don't think there is a roadmap for them yet.
Nicholas Scott
Is there someone who I can talk to a bit about those ideas?
Well, we can talk here, or were you speaking of something different?
I PM'd you, to see if that function works, thanks!
Thanks, we'll continue on there.
