Can't start nagios if apache is in custom location
vinothsethuram
I couldn't start nagios due to apache's custom location.
service nagios start
/etc/init.d/nagios: 20: .: Can't open /etc/rc.d/init.d/functions
Can you please help to start nagios?
Re: Can't start nagios if apache is in custom location
The error you are receiving is due to missing LSB init functions, not a custom apache location. What distribution are you running?vinothsethuram wrote:I couldn't start nagios due to apache's custom location.
vinothsethuram
Ubuntu 13.10abrist wrote:The error you are receiving is due to missing LSB init functions, not a custom apache location. What distribution are you running?vinothsethuram wrote:I couldn't start nagios due to apache's custom location.
I presume you are running core 4. There have been issues with debian systems and the init scripts. See the following thread:
http://support.nagios.com/forum/viewtop ... nit#p76464
vinothsethuram
I executed below command
apt-get install daemon.
But confused with hack script. Which File I need to edit and where is the contents be copied or replaced?
You need to follow the other post in that thread which links back to the altered nagios init script.
http://support.nagios.com/forum/viewtop ... =20#p64091
It is a drop in replacement for the nagios init script.
vinothsethuram
After replacing the script, I am getting error
sudo service nagios restart
$Stopping nagios:
$Starting nagios:
But nagios dashboard is not working .. http://ipaddress/nagios/ is giving following error
Not Found
The requested URL /nagios/ was not found on this server.
$Stopping nagios:
$Starting nagios:
Not Found
Restart httpd:
Or:
Do you have a vhost file for nagios?
Or:
service httpd restartCode: Select all
service apache2 restartCode: Select all
ls -la /etc/httpd/conf.dCode: Select all
ls -la /etc/apache2/sites-available/Former Nagios employee
vinothsethuram
abrist wrote:Restart httpd:Or:Code: Select all
service httpd restartDo you have a vhost file for nagios?Code: Select all
service apache2 restartOr:Code: Select all
service apache2 command executed fine. But still getting page not found error.
log for ls -la /etc/httpd/conf.d
total 12
drwxr-xr-x 3 root root 4096 Nov 19 16:30 .
drwxr-xr-x 3 root root 4096 Nov 19 16:30 ..
drwxr-xr-x 2 root root 4096 Nov 25 05:27 nagios.conf
log for ls -la /etc/apache2/sites-available/
total 20
drwxr-xr-x 2 root root 4096 Nov 21 03:53 .
drwxr-xr-x 8 root root 4096 Nov 21 03:53 ..
-rw-r--r-- 1 root root 1327 Jul 24 06:45 000-default.conf
-rw-r--r-- 1 root root 6432 Jul 20 16:44 default-ssl.conf
Lets copy the nagios vhost fole to sites-available:
And then restart apache:
cp /etc/httpd/conf.d/nagios.conf /etc/apache2/sites-available/Code: Select all
service apache2 restartFormer Nagios employee
