Can't start nagios if apache is in custom location
Re: Can't start nagios if apache is in custom location
Correct path is /apps/apache-httpd/ not /apps/apache-http/
- -fno-stack-protector
Did you configure this when building nagios, such as ./configure --webdir=/apps/apache-httpd/nagios/ ? That likely is not a correct config option, but if you are not going to use the standards that configure and make expect, gcc and make will not create your cgi's and nagios binaries correctly. At this point I can only assume you wish to use that directory instead of /var/www or wherever it may currently be in ubuntu land, is this thought correct?
Not sure. I followed below installation guide.
http://nagios.sourceforge.net/docs/3_0/ ... buntu.html
We are looking for the location of your apache vhost files, as we need to copy the nagios vhost file into it.
ls -la /apps/apache-httpd/conf.d/
abrist wrote:We are looking for the location of your apache vhost files, as we need to copy the nagios vhost file into it.Code: Select all
root@velocitylinux:~/downloads/nagios-plugins-1.5# ls -la /apps/apache-httpd/
total 68
drwxr-xr-x 15 velocity velocity 4096 Nov 21 00:45 .
drwxrwxr-x 8 velocity velocity 4096 Dec 4 00:21 ..
drwxr-xr-x 2 velocity velocity 4096 Nov 15 02:38 bin
drwxr-xr-x 2 velocity velocity 4096 Nov 15 02:38 build
drwxr-xr-x 2 velocity velocity 4096 Nov 15 02:38 cgi-bin
drwxr-xr-x 4 velocity velocity 4096 Dec 4 00:35 conf
drwxr-xr-x 3 velocity velocity 4096 Nov 15 02:38 error
drwxr-xr-x 2 velocity velocity 4096 Dec 10 01:56 htdocs
drwxr-xr-x 3 velocity velocity 4096 Nov 15 02:38 icons
drwxr-xr-x 2 velocity velocity 4096 Nov 15 02:38 include
drwxr-xr-x 3 velocity velocity 4096 Nov 15 02:38 lib
drwxr-xr-x 2 velocity velocity 4096 Dec 4 00:28 logs
drwxr-xr-x 4 velocity velocity 4096 Nov 15 02:38 man
drwxr-xr-x 14 velocity velocity 12288 Jul 15 2013 manual
drwxr-xr-x 2 velocity velocity 4096 Nov 15 04:10 modules
How about:
ls -la /apps/apache-httpd/conf/
root@velocitylinux:~/downloads/nagios-plugins-1.5# ls -la /apps/apache-httpd/conf/
total 108
drwxr-xr-x 4 velocity velocity 4096 Dec 4 00:35 .
drwxr-xr-x 15 velocity velocity 4096 Nov 21 00:45 ..
drwxr-xr-x 2 velocity velocity 4096 Nov 15 02:38 extra
-rw-r--r-- 1 velocity velocity 18425 Dec 4 00:28 httpd.conf
-rw-r--r-- 1 velocity velocity 13077 Nov 15 02:38 magic
-rw-r--r-- 1 velocity velocity 53011 Nov 15 02:38 mime.types
drwxr-xr-x 3 velocity velocity 4096 Nov 15 02:38 original
-rw-rw-r-- 1 velocity velocity 232 Nov 21 00:45 workers.properties
total 108
Can you attach a copy of:
/apps/apache-httpd/conf/httpd.conf
abrist wrote:Can you attach a copy of:Code: Select all
root@velocitylinux:~# sudo /apps/apache-httpd/conf/httpd.conf
sudo: /apps/apache-httpd/conf/httpd.conf: command not found
Can you attach a copy of it?
