Can u tell me what does make distclean and make clean do?? Would this change or modify my existing checks and services? ?
Regards,
Farooq Ahmed
Error Whoops! Error: Could not open CGI config file
- -fno-stack-protector
Re: Error Whoops! Error: Could not open CGI config file
This only removes objects built by gcc when building the nagios cgi's and core engine. It will not effect the binaries in place or any configurations you have done.
Do I need to restart nagios after doing that?
Regards,
Farooq Ahmed
Regards,
Farooq Ahmed
you should probably stop the nagios service, compile and install, and then start nagios again.
Will update once done.
Thanks for the advice.
Regards,
Farooq Ahmed
Regards,
Farooq Ahmed
Great, let us know.
Hi,sreinhardt wrote:Well the cgis are coded to look in certain places via the ./configure options you originally listed. Are these still using the prefix with nagios-4.0.2? Probably the easiest route would be to go back to the nagios build directory and run the following commands.This will use all the normal defualts that specify that everything should be based off /usr/local/nagios/Code: Select all
make distclean; make clean ./configure make all make install
I was about to carry out the steps. Do i need to include "--with-command-group=nagcmd" with "./configure "??
Regards,
Farooq Ahmed
Most likely not as I believe it is default now. But it wouldn't hurt to include it
It worked. Thanks a million. Now all .cgi's work.
Regards,
Farooq AHmed
Regards,
Farooq AHmed
