nrpe 2.15 for hpux 11.31
pkarr
Post by pkarr »
I'm trying to install the new version of nrpe-2.15 for HPUX 11.31ia-64 so that I can use command args. So far its not working.
I've tried to do this with the earlier versions without success. I have the nrpe 2.12 depot package(http://www.mayoxide.com/naghpux/) working but, alas, it doesn't use command args. I have studied the blogs (Cyrus doing the blog thing,etc) on the subject and tried the fixes with no luck. I'd appreciate your help.
Here's what I get when I run configure. At this point it doesn't matter whether I specify the ssl args or not. I get the same error.
$ PATH="$(cat /etc/PATH):/usr/local/bin" ./configure --with-libintl-lib=/opt/gtk2.6/lib --with-ssl-inc=/opt/openssl/include/openssl --with-ssl-lib=/opt/openssl/lib/hpux64 --enable-command-args
checking for a BSD-compatible install... ./install-sh -c
checking build system type... ia64-hp-hpux11.31
checking host system type... ia64-hp-hpux11.31
checking for gcc... gcc
checking for C compiler default output file name... configure: error: C compiler cannot create executables
See `config.log' for more details.
thanks,
Penny
Penny Karr | IT Infrastructure Monitoring
Harvard Vanguard Medical Associates, an Affiliate of Atrius Health
254 Second Avenue | Needham, MA 02494
P (781) 292-1853 | F (781 292-1980 | http://www.harvardvanguard.org
Email: [email protected]
abrist
Red Shirt
Re: nrpe 2.15 for hpux 11.31
Post by abrist »
It looks like you are missing a library:
/usr/lib/hpux32/dld.so: Unable to find library 'libintl.so'.
And this is killing the gcc version check among other checks and is subsequently failing.
Can you make sure that you have: gettext, libiconv and zlib installed?
I don't know much about HPUX, but looking at the config.log errors, it seems to me that the compiler is failing, most probably because of missing dependencies. Try installing the gettext, libiconv and maybe zlib then try compiling again. Hope this helps.
