Running XI on Windows 7
Sbergonzi
Post by Sbergonzi »
I'm trying to run XI on my Windows 7 desktop using the virtual machine install. I've tried to run the nagiosxi.vmc using the nagiosxi.vhd and it fails. The displays shows Segmentation fault errors.
Is there other configuration required?
thank you!
Re: Running XI on Windows 7
Post by slansing »
Which VM did you download? You should be able to load it straight in without having to fiddle too much.
Sbergonzi
Post by Sbergonzi »
nagiosxi-2012r2.9-virtualpc.zip
Windows6.1-KB958559-x86-RefreshPkg.msu first for the VM.
Sbergonzi
Post by Sbergonzi »
nagiosxi-2012r2.9-virtualpc.zip after running Windows6.1-KB958559-x86-RefreshPkg.msu for the windows VM installation
Post by slansing »
So you are trying to run a windows VM from your workstation, and inside of that VM you are trying to run another VM? (Nagios XI)?
Sbergonzi
Post by Sbergonzi »
Sorry, I ended up posting the same message twice.
On my Windows 7 desktop I'm trying to run a VM with the nagios hd, single instance.
abrist
Red Shirt
Post by abrist »
Sbergonzi wrote: The displays shows Segmentation fault errors.
You will see this when you are not running the right architecture. Are you using the 64 bit vm appliance? If so, does your copy of vmware workstation support 64bit vms?
Are you using a VMWare product like Player or Workstation, or are you using Microsoft VirtualPC?
Sbergonzi
Post by Sbergonzi »
Microsoft windows virtual pc, 32 bit -
Sbergonzi
Post by Sbergonzi »
The error in the VM states:
Segmentation fault
Segmentation fault
Segmentation fault
dracut: FATAL; No or empty root= argument
dracut: Refusing to continue
Segmentation fault
Kernel panic - not syncing : attempted to kill init!
Pid: 1, comm: init Not tainted 2.6.32-358.2.1.el6.i686 #1
Call Trace:
[] ? panic...
[] ? do_exit....
[] ? do_group_exit....
[] ? sys_exit_group....
[] ? sysenter_do_call ....
