check_http: Invalid option - SSL is not available
vinothsethuram
Post by vinothsethuram »
I installed Nagios 4.0.2. I'm getting error - check_http: Invalid option - SSL is not available
Here is the steps which I took to resolve the issue, but still getting same error.
1)
yum install openssl
Package openssl-1.0.0-27.el6_4.2.x86_64 already installed and latest version
2) I went to Nagios plugin folder and executed following commands
./configure --with-openssl=/usr/bin/openssl
 make clean
 make
 make install
and restarted the nagios service.[code]
[/code]
Please help to resolve the issue
sreinhardt
-fno-stack-protector
Re: check_http: Invalid option - SSL is not available
Post by sreinhardt »
You would actually need to install the openssl-devel package, or at least thats how it's named in cent land. The plugins need the openssl sources to compile against them, not the binary. Then you actually should not need to specify the configure switch for where openssl is.
csekar
Post by csekar »
Vinoth, this worked. Thanks
Going to lock the thread as it is somewhat old, but it will still be visible for reference.
