Notification Preferences
jlee
Post by jlee »
In the Notification Preferences I have unticked host Flapping and Service Flapping.
However, I am still receiving notification for Flapping.
Do I have to go to every host to turn this off?
James
mguthrie
Re: Notification Preferences
Post by mguthrie »
The best way to accomplish this per user would actually be to disable flapping notifications for the contact, or disable this for the host or service template that is used. The "xiwizard_generic_host" and "xiwizard_generic_service" templates are referenced by almost everything, so that would be another way to turn them off globally, and then you could override the template at the host or service level if you needed to.
jlee
Post by jlee »
Thanks I will give it a go.
mguthrie
Post by mguthrie »
Sounds good, let us know if you have any additional questions.
gglassman
Post by gglassman »
Thank you for this suggestion. I had the same question.
