Today, I have upgraded NagiosXI from r1.2 to r1.5 of 2011.
After the upgrade, I found out that the user list of the pull down menu of user in backend API URL is gone.
There is no user name to select. Only thing that shows in the poll down menu is the default text of SELECT ONE.
How can I get the backend API URL again?
removed from user pull down in backend API URL after r1.5
Re: removed from user pull down in backend API URL after r1
Can you try deleting and then reinstalling the component through the Manage Components page? I just tested on my system and so far I haven't been able to recreate this issue.
It cleared out the problem.
I am getting the backendapiurl ok now.
Thanks.
Thanks.
Good deal! Let us know if you have any other questions.
