I have problem with critical thereshold. I would like check FAN in my device and i know that SNMP string from 9000 to 11000 is OK (9000,11000) and another value is critical.
My configuration don`t work and I don`t want why, i check my configuration with https://nagios-plugins.org/doc/guidelines.html
host_name HOSTNAME
service_description FAN
check_command check_snmp!-P 2c -C publictest -o X.X.X.X.X.X.X.X.X.X.X.X.X -c 9000:11000 -r SNMP OK - \d{0}
}What it is "-r" and this command "-r SNMP OK - \d{0}"?
Table 3. Example ranges
Range definition
Generate an alert if x...
10 < 0 or > 10, (outside the range of {0 .. 10})
10: < 10, (outside {10 .. ∞})
~:10 > 10, (outside the range of {-∞ .. 10})
10:20 < 10 or > 20, (outside the range of {10 .. 20})
@10:20 ≥ 10 and ≤ 20, (inside the range of {10 .. 20})
