nrdp and timing out
Re: nrdp and timing out
oh sorry. I think I was unclear earlier. I can't get nrdp to work on any of the hosts. I did try nsca on one of the hosts and that worked.
But to answer your questions, no, all the hosts have the same config options.
- -fno-stack-protector
Just to make sure, are your nagios.cmd locations the same as well?
Looks like core has it as here: /usr/local/nagios4/var/rw/nagios.cmd
grep nagios.cmd /usr/local/nrdp/server/config.inc.php
yes:
$ grep nagios.cmd /usr/local/nrdp/server/config.inc.php
$cfg["command_file"]="/usr/local/nagios4/var/rw/nagios.cmd";
$ ls -lgG /usr/local/nagios4/var/rw/nagios.cmd
prw-rw---- 1 0 Apr 3 11:25 /usr/local/nagios4/var/rw/nagios.cmd
What are these permissions
and is selinux enabled?
ls -ld /usr/local/nagios4/var/spool/checkresults
getenforce
SELinux is disabled. I talked to other admins around here and was told that it is turned off intentionally. Is it necessary to have that enabled? I've also been asked to ask you the rationale behind using SELinux.
thanks!
thanks!
No, I was making sure it wasn't enabled and causing problems....jssingh wrote: Is it necessary to have that enabled? I've also been asked to ask you the rationale behind using SELinux.
ah. oops.No, I was making sure it wasn't enabled and causing problems....
as usual, to keep with the requirements here, these are not the actual user/group names.
$ ls -ld /usr/local/nagios4/var/spool/checkresults
drwxrwxr-x 2 nagios_user nagios_group 4096 Mar 31 14:50 /usr/local/nagios4/var/spool/checkresults
drwxr-xr-x 3 nagios_user nrdp_group 4096 Oct 31 13:58 /usr/local/nagios4/var/spool
drwxrwxr-x 6 nagios_user nagios_group 4096 Apr 7 14:48 /usr/local/nagios4/var
drwxr-xr-x 9 nagios_user nagios_group 4096 Dec 9 15:26 /usr/local/nagios4
Ok, your last post gave me a clue on what might be happening...
Is the user that apache runs under a member the your nagios_group, this being the same group assigned to the following directory?
no ... I changed the group and it worked! Thank you!!!
