Add inode check to check_snmp_storage_wizard.pl?
eclypse
Post by eclypse »
The check_disks_snmp.pl plugin supports checking inodes of monitored filesystems, however, the check_snmp_storage_wizard.pl plugin that is the default plugin used by the Linux SNMP Monitoring Wizard does not. Would it be possible to extend this plugin to support checking inode usage of monitored partitions?
sreinhardt
-fno-stack-protector
Re: Add inode check to check_snmp_storage_wizard.pl?
Post by sreinhardt »
I don't see why this would not be possible for at least operating systems that offer that information via snmp. However this is not something that we maintain. You might try contacting the developer Patrick (patrick at proy.org).
