Need to monitor check every 2 or 3 seconds
madhudeva
Post by madhudeva »
Hi Team..
We had a critical service running and the check runs every one minute to monitor.. I tried 02, 0.2 but it takes 2 minutes. is there any way to add seconds format? ( need to run every 3 seconds )
Regards,
Madhu
Re: Need to monitor check every 2 or 3 seconds
Before I say this, we *strongly* advise against doing checks every second. That will seriously slow things down. Even if it is just one host or service that is doing this, it is neither easy to set up nor recommended. We aren't just saying this, it really is that bad.
What we would recommend instead is to run a passive check from that host and then only report on a problem from that host. If this is possible I would do this instead.
Post by 455157 »
The passive model does seem like a good idea in this case.
Checking (active) that often, I think the checks could even begin to overlap, where the next check happens before the last check completes- depending on the method/plugin. I wonder how XI responds when that happens.
Could checking this often also hurt the performance of the monitored host, again depending on the specifics?
madhudeva
Post by madhudeva »
I had a custom script as below that checks the SMF services and this is Active check runs every minute as of now.. How do I achieve the same through passive check and where do we mention check time in passive check? If we cannot mention check time how often this passive check monitors the service?
#!/bin/bash
PATH="/usr/bin:/usr/sbin:/bin:/usr/local/bin:/sbin"
LIBEXEC="/markets/nagios/libexec"
. $LIBEXEC/utils.sh
for i in `svcs -o SVC,STATE markets/* | /usr/xpg4/bin/grep -iE "(maintenance)" | awk '{print $1}'| sed 's#site/##g'`;do
mservices=$i" "$mservices
done
if [ "$mservices" = "" ]; then
echo "All services ok"
exit $STATE_OK
else
printf "Service(s) in maintenance: %s\n" "$mservices"
exit $STATE_CRITICAL
fi
Passive checks are pretty easy to set up, you just need to do some reading and a bit of configuration on the remote server:
http://assets.nagios.com/downloads/nagi ... ith_XI.pdf
That doc is the general overview of passive checks using NSCA, and it links to the specific NSCA doc for the remote host. Still with passive checks I would not recommend more than a 1-minute interval even from a passive check.
clive.dias
Post by clive.dias »
Thanks.We will check and get back to you
I assume by your emails you guys are from the same organization. We'll keep this thread open until one of you returns.
