Hi I am use Nagios XI 2012R2.9, VMWare downloaded from Nagios.
Some times in my instalation I miss the DASHBOARD Monitoring Engine Status Missing, as we can see bellow.
How can we solve this?
Regards
Gerald
Re: DASHBOARD Monitoring Engine Status Missing
Can you elaborate on "Some times"? Do you see any pattern? How often does it happen?
Do you have any config errors? Are the services running?
Does restarting the services "fix" the issue?
What is the output of the following commands?
service nagios status
service ndo2db status
service crond statusWhat is the output of the following commands?
tail /var/log/messages
tail /var/log/httpd/error_log
tail /var/log/cron
chage -l nagios
chage -l apacheBe sure to check out our Knowledgebase for helpful articles and solutions!
All services are running...
[root@SPAM-VM-NGS01 ~]# service nagios status
nagios (pid 10827) is running...
[root@SPAM-VM-NGS01 ~]# service ndo2db status
ndo2db (pid 39167) is running...
[root@SPAM-VM-NGS01 ~]# service crond status
crond (pid 38667) is running...
I restart all services, but the probems still happen.
Here are the logs.
Thanks Geraldo
Here are the logs.
Thanks Geraldo
Can your machine connect to localhost from the console?
curl http://localhost/nagiosxiRe: DASHBOARD Monitoring Engine Status Missing
Yes, we can!
I Fix the problem, I did change some php.ini parameters and the problem was fix.
max_execution_time = 90 ; original was 60
max_input_time = 90 ; original was 60
memory_limit = 256M ; original was 128
Thanks for Help!
Thanks for Help!
