we are running NagiosXI 2012 V2.9 with the latest updated version of the Bulk Modification Tool loaded. When I try to modify the host or service notification period setting it removes the notifcation_period completely
from the cfg files and shows the setting blanked out on the CCM GUI after the change is applied.
Is this a know issue with the notification period and the Bulk modification tool ?
Vinny
Bulk Modification Tool 2012 V2.9 change notification period
Re: Bulk Modification Tool 2012 V2.9 change notification per
System installed on RHEL 6.3 x86_64 with manual install of nagiosxi.
When you go to make the change, what value are you typing in the box? Is it a time period you have defined?
yes it is a time period I have defined it's named online_time_period and is set from Friday to Saturday 07:30 to 18:30.
Let's verify - you entered the online_time_period's ID (last column under the CCM->Timeperiods) into the "Value" field under the Bulk Modifications Tool, correct? Did you apply configuration after adding the notification_period to your hosts/services? Do you have any config errors?
Hi, the steps carried out are as follows
Configure --> Core Configuration Manager --> Bulk Modifications
Change a Single Config Config Option
notification_period
specify custom timeperiod in the value
specify the services to apply to and click on Apply Configuration
No errors returned
When I look at the notification_period on the service selected it's removed.
Vincent
notification_period
No errors returned
Vincent
Can you elaborate on "specify custom timeperiod in the value"? Is this the ID of your timeperiod or some random value?
Go to CCM->Alerting->Time Periods and post a screenshot of this page. Highlight the value (ID) of the "custom timeperiod" that you are trying to enter.
