Installation Problem (Run the AutoDiscovery Wizard
faisalrehman1975
Post by faisalrehman1975 »
An installation errror was detected. The following steps must be completed before using this component:
•Run the setup script. To do this, login to the Nagios XI server as the root user and issue the following commands:
chmod +x /usr/local/nagiosxi/html/includes/components/autodiscovery/setup.sh
Re: Installation Problem (Run the AutoDiscovery Wizard
Did you run these commands?
faisalrehman1975
Yes!
The command Never Worked
sreinhardt
-fno-stack-protector
Post by sreinhardt »
Did you get any output when running those commands? We need something to work with so that we can help you out. Any and all details help!
faisalrehman1975
Error: Try 'chmod --help' for more information
faisalrehman1975
[root@localhost ~]# chmod +x /usr/local/nagiosxi/html/includes/components/autodiscovery/setup.sh
After Runing this Command come with the error message
chmod: missing operand after '+x /usr/local/nagiosxi/html/includes/components/autodiscovery/setup.sh'
try 'chmod --help' for more information
Run the following commands and show us the output:
ll /usr/local/nagiosxi/html/includes/components/autodiscovery/setup.sh
chmod --version
sestatus
