Regard
PO
Edit: Here my verification file :
Nagios Core 3.5.0
Last Modified: 03-15-2013
License: GPL
Reading configuration data...
Read main config file okay...
Processing object config directory '/usr/local/nagios/etc/static'...
Processing object config file '/usr/local/nagios/etc/static/xitest.cfg'...
Processing object config file '/usr/local/nagios/etc/static/xitemplates.cfg'...
Processing object config file '/usr/local/nagios/etc/static/xiobjects.cfg'...
Processing object config file '/usr/local/nagios/etc/contacttemplates.cfg'...
Processing object config file '/usr/local/nagios/etc/contactgroups.cfg'...
Processing object config file '/usr/local/nagios/etc/contacts.cfg'...
Processing object config file '/usr/local/nagios/etc/timeperiods.cfg'...
Processing object config file '/usr/local/nagios/etc/commands.cfg'...
Processing object config file '/usr/local/nagios/etc/hostgroups.cfg'...
Processing object config file '/usr/local/nagios/etc/servicegroups.cfg'...
Processing object config file '/usr/local/nagios/etc/hosttemplates.cfg'...
Processing object config file '/usr/local/nagios/etc/servicetemplates.cfg'...
Processing object config file '/usr/local/nagios/etc/servicedependencies.cfg'...
Processing object config file '/usr/local/nagios/etc/serviceescalations.cfg'...
Processing object config file '/usr/local/nagios/etc/hostdependencies.cfg'...
Processing object config file '/usr/local/nagios/etc/hostescalations.cfg'...
Processing object config file '/usr/local/nagios/etc/hostextinfo.cfg'...
Processing object config file '/usr/local/nagios/etc/serviceextinfo.cfg'...
Processing object config directory '/usr/local/nagios/etc/hosts'...
Processing object config file '/usr/local/nagios/etc/hosts/ABUS_VPN-1.cfg'...
Processing object config file '/usr/local/nagios/etc/hosts/ASL_VPN-1.cfg'...
Processing object config file '/usr/local/nagios/etc/hosts/BC_TEL_MIPU.cfg'...
Processing object config file '/usr/local/nagios/etc/hosts/BL_CISCO_WIFI.cfg'...
Processing object config file '/usr/local/nagios/etc/hosts/BC_VPN-1.cfg'...
Processing object config file '/usr/local/nagios/etc/hosts/BL_VPN-1.cfg'...
Processing object config file '/usr/local/nagios/etc/hosts/localhost.cfg'...
Processing object config file '/usr/local/nagios/etc/hosts/BC_LNK_Telebec.cfg'...
Processing object config directory '/usr/local/nagios/etc/services'...
Processing object config file '/usr/local/nagios/etc/services/ASL_VPN-1.cfg'...
Processing object config file '/usr/local/nagios/etc/services/BC_TEL_MIPU.cfg'...
Processing object config file '/usr/local/nagios/etc/services/BC_VPN-1.cfg'...
Processing object config file '/usr/local/nagios/etc/services/localhost.cfg'...
Processing object config file '/usr/local/nagios/etc/services/BC_LNK_Telebec.cfg'...
Checking services...
Checked 12 services.
Checking hosts...
Checked 8 hosts.
Checking host groups...
Checked 16 host groups.
Checking service groups...
Checked 0 service groups.
Checking contacts...
Checked 2 contacts.
Checking contact groups...
Checked 2 contact groups.
Checking service escalations...
Checking service dependencies...
Checked 0 service dependencies.
Checking host escalations...
Checked 0 host escalations.
Checking host dependencies...
Checked 0 host dependencies.
Checking commands...
Checked 108 commands.
Checking time periods...
Checked 8 time periods.
Checking for circular paths between hosts...
Checking for circular host and service dependencies...
Checking misc settings...
Total Warnings: 0
Total Errors: 0
Things look okay - No serious problems were detected during the pre-flight checkThere you go ! IT seem to be the problem ! I have fallow the guide to change the timezone and everything.
[root@nagios ~]# grep "date.timezone" /etc/php.ini
; http://www.php.net/manual/en/datetime.c ... e.timezone
date.timezone =Canada/Eastern
[root@nagios ~]# php -r 'echo date("D M j G:i:s T Y")."\n";'
Wed Apr 23 8:30:43 EDT 2014
[root@nagios ~]# date
Wed Apr 23 12:30:44 UTC 2014
[root@nagios ~]
Regard
PO
