I have set up multiple hosts via the wizards and all are showing as 'up'. One host i configured manually, piece mail if you will via Nagios core. This host continually shows a status of 'pending'.
I compared its configuration with other hosts (items such as 'manage variable definitions' and 'status image') and all looks the same. I'm missing something, just don't know what it is. This image shows the pending one and the others. i scheduled an immediate check and it hasn't changed.
thanks!
host state not changing
Re: host state not changing
Can you show the configuration for this host? CCM > Hosts > Click the diskette icon next to the host and paste the output here, highlight the configuration information once it is in the reply text box, then click the "Code" button.
Does first_notification_delay mean something? I noticed this host has it set(to 0) and no other host has it at all.
# Host configuration file
# Created by: Nagios QL Version 3.0.3
# Date: 2014-05-07 17:55:54
# Version: Nagios 3.x config file
# Nagios QL will overwite all manual settings during the next update
define host {
host_name ctdapanwnaa1tsg
use xiwizard_windowsserver_host
alias Alfresco Auth Server
address 10.209.22.71
max_check_attempts 5
check_interval 60
retry_interval 1
check_period workhours
contacts bergonzis
notification_interval 60
notification_period workhours
first_notification_delay 0
_xiwizard windowsserver
register 1
# END OF FILE
#Re: host state not changing
That's just the delay in minutes after an issue is raised before an alert gets sent.
it's now changed to 'up' and the timestamp is corrected. i guess i didn't wait long enough.
ok to close issue -
ok to close issue -
