XI installation errors
rickwilson7425
Post by rickwilson7425 »
We are running RedHat 6.5.
System has a valid rhn systemid.
We have configured our proxy access according to info on nagios FAQ's.
Getting this error when running "1-prereqs":
Error: Package: nagiosxi-deps-2012r2.9-1.noarch (/nagiosxi-deps-2012r2.9-1.noarch)
Requires: perl(Net::SMTP::TLS)
You could try using --skip-broken to work around the problem
You could try running: rpm -Va --nofiles --nodigest
Looking at the perl installation it shows that the package is installed:
[root@dennagxis1 nagiosxi]# instmodsh
Available commands are:
l - List all installed modules
m <module> - Select a module
q - Quit the program
cmd? l
Installed modules are:
Archive::Tar
Archive::Zip
CPAN
CPAN::Meta::Requirements
CPAN::Meta::YAML
Compress::Raw::Bzip2
Compress::Raw::Zlib
Cwd
Data::Dumper
Digest::SHA
ExtUtils::CBuilder
ExtUtils::MakeMaker
File::HomeDir
File::Temp
File::Which
IO::Compress
IO::Zlib
IPC::Run3
Module::Build
Module::Metadata
Net
Net::SMTP::TLS
Parse::CPAN::Meta
Perl
Perl::OSType
Probe::Perl
Term::ReadKey
Term::ReadLine
Test::Harness
Test::Script
Test::Simple
Text::Glob
YAML
version
cmd? q
Any suggestions?
technick
Re: XI installation errors
Post by technick »
Possibly try removing the version you have and letting it get re-added?
You could ALSO modify the installation script and have it skip installing that package.
Nagios Jedi in training.
sreinhardt
-fno-stack-protector
Post by sreinhardt »
Do you have the optional repo enabled?
yum repolist all
rickwilson7425
Yes, here it what it says;
[root@dennagxis1 nagiosxi]# yum repolist all
Loaded plugins: downloadonly, product-id, rhnplugin, security, subscription-manager
This system is not registered to Red Hat Subscription Management. You can use subscription-manager to register.
This system is receiving updates from RHN Classic or RHN Satellite.
repo id repo name status
epel Extra Packages for Enterprise Linux 6 - x86_64 enabled: 10,769
epel-debuginfo Extra Packages for Enterprise Linux 6 - x86_64 - Debug disabled
epel-source Extra Packages for Enterprise Linux 6 - x86_64 - Source disabled
epel-testing Extra Packages for Enterprise Linux 6 - Testing - x86_64 disabled
epel-testing-debuginfo Extra Packages for Enterprise Linux 6 - Testing - x86_64 - Debug disabled
epel-testing-source Extra Packages for Enterprise Linux 6 - Testing - x86_64 - Source disabled
rhel-source Red Hat Enterprise Linux 6Server - x86_64 - Source disabled
rhel-source-beta Red Hat Enterprise Linux 6Server Beta - x86_64 - Source disabled
rhel-x86_64-server-6 Red Hat Enterprise Linux Server (v. 6 for 64-bit x86_64) enabled: 12,494
rhel-x86_64-server-optional-6 RHEL Server Optional (v. 6 64-bit x86_64) enabled: 7,085
rpmforge RHEL 6Server - RPMforge.net - dag enabled: 4,682
rpmforge-extras RHEL 6Server - RPMforge.net - extras disabled
rpmforge-testing RHEL 6Server - RPMforge.net - testing disabled
repolist: 35,030
sreinhardt
OK so you are definitely all set on repos, hopefully they all connect.. Anyway, lets check what version yum thinks you have installed. I should note here, that installing from cpan will not properly resolve the dependency for yum, it will need to be an rpm install.
yum list installed perl-Net-SMTP-TLS
What is the output of the following command?
yum list installed | grep -i "perl-Net-SMTP-TLS"
rickwilson7425
Here is the output:
rwilson@dennagxis1:/remote/home/rwilson $ sudo yum list installed | grep -i "perl-Net-SMTP-TLS"
perl-Net-SMTP-TLS.noarch 0.12-1.el6.rf @rpmforge
rickwilson7425
The perl package was reninstalled with rpm and it is working now.
We are moving ahead with the install scripts at this point.
Shall we keep this open for a bit or are you good?
rickwilson7425
Let's keep it open for today at least.
We are having a problem getting updates but it is probably a proxy issue.
Will let you know.
Thanks.
